After stereo install my speakers will stop working after i hit a bump?!?!?!?
Old Aug 2, 2002 | 09:23 AM
ford's Avatar
Angry After stereo install my speakers will stop working after i hit a bump?!?!?!?
What is going on. If i hit a bump hard enough the head unit still shows on and it shows that it is still playing(equalizer) and it seems to work fine except the fact that it doesnt come out from the speakers.
Then i hit some small bumps and it starts to come back for like 1 second at a time. Then i hit a big bump and it will come back completely until i hit another large bump.
Almost like the wires are grounding out or something.
What can i look for and where to see what is going on?
I would take it back to the stereo place but they are closed till tuesday and i will be outta town anyway.
Old Aug 2, 2002 | 10:33 AM
Bando's Avatar
Post
If you just replaced the head unit, I'd say the either a ground wire or a speaker wire at the back came loose from its electrical tape. IF you replaced speakers as well, it could be a loose wire at a speaker.
Or its skipping really bad?
Old Aug 2, 2002 | 10:51 AM
ford's Avatar
Post
Nope it doesnt skip at all.
And would a speaker wire make all the speakers stop working???
They all just stop with a bump.
Old Aug 2, 2002 | 11:08 AM
Gotbass's Avatar
Post
Are all the speakers running of an amp? or right off the deck?
You said the CD player stays on when the sound is gone?
Shon
2000 Mercury Cougar Special Edition
http://www.geocities.com/bustatail.geo/smith.html
Old Aug 2, 2002 | 11:13 AM
ford's Avatar
Post
Nope no amp and no subs. Speakers run straight from the deck. My stereo isnt all that yet.
Where would they ground it at?? Maybe i could check there
Old Aug 2, 2002 | 11:19 AM
Gotbass's Avatar
Post
If your CD player stays on, I'd check the plug behind the head unit. Most decks have a plug for power/ground/dimmer, etc, and a seperate plug for your speaker outs. My guess would be one of the plugs isn't quite locked in.
If the CD player is turning off too, then I'd def. check that ground.
Shon
Old Aug 3, 2002 | 11:55 AM
ford's Avatar
Post
Hmm took the whole head unit out of the car. All of it was plugged in. Turned on the car and the unit came on and the equalizer showed it was playing music.(but there was no sound) So i beat on the head unit seeing if it was the unit that was messing up and when i hit a bump if it was just something internally wrong with it.
But it didnt do a thing. So i put everything back and got in the car to go get something to drink. Hit a few small bumps the music scrathes in then out hit a big bump and it comes to life like nothing was wrong.
Then on the way back hit the same hard bump and it goes off again. Get at home turn off the car. And it sounds as if the stereo is playing ever so softly but could never make it out.
Something has to be wrong. I dont think its the head unit(it used to be in my truck and it never once did this) plus i beat on the head unit by hand.
So something has to be grounding out somewhere right? But what can make all 4 speakers just stop playing?
I am sooo confused i love to hear music and drive WAY too much not to have anything to listen to.
Thanks for all your help
Old Aug 3, 2002 | 02:39 PM
x7x7's Avatar
Post
Did you replace speakers too? It sounds to me like one of the speaker wires is shorting to ground.
Drive the car until the stereo stops working then with it still not working remove the HU and test the speaker resistances with a DMM (digital multimeter). One should be different from the others. When you find which one you can remove the speaker and see what's going on.
'96 Firebird Formula M6
Performance
Custom cut-out, Homemade 4" CAI with 9" cone filter, !CAGS, TB Bypass, Energy Suspension Trans. Mount, Taylor 8mm Wires, Pro 5.0 shifter, LCAs, Stock 3.42 gears
Stereo
Sony Xplod MP450X MP3 Headunit, Sony XE-90MKII Half DIN EQ, MTX RTX01A Crossover, 2 12" Clarions, powered by 2 Bridged Kenwood KAC-728S amps, Infinity Reference Series component set up front, powered by Kenwood KAC-628, EFX 1 farad cap, 4 gauge wire to cap, 10 gauge to amps
Pic
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Rod Bender
Jan 3, 2015 03:15 PM
ANDYZ28
Dec 29, 2014 09:13 PM
BOOGER
Jul 25, 2002 02:42 PM
