94 camaro z28 starter/ignition issue
Old May 12, 2009 | 01:38 PM
RKPsk8er's Avatar
my car wasn't starting so i replaced the starter and had the battery replaced under waranty.
everything worked great but today when i shut the car off, i noticed that the starter was still running (disengaged) even after i took the key out of the ignition. finally, i had to disconnect the batt to shut it off, i put the key in and turned it all the way back then took it out again, reconnected the battery, and started the car normally, but once again, when i turned it off, the starter continued running.
has anyone heard anything like this? does it sound like a starter issue or an ignition switch issue?
Old May 12, 2009 | 02:26 PM
I would check your starter wiring, since you just replaced it.
Old May 12, 2009 | 04:29 PM
RKPsk8er's Avatar
i doublechecked it and it was good. it worked fine for a few days and started messing up today.
also, i just removed the starter and had it tested at advance auto, they said it was fine but they are having it replaced anyways.
could bypassing the vats have any effect on this problem?
Old May 13, 2009 | 03:11 PM
RKPsk8er's Avatar
problem fixed. the new remanufactured starter shorted out on the inside.
CamaroHeed
Mar 18, 2020 09:50 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
siguy
Nov 27, 2014 10:07 AM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
