Replacing Oil Level Sensor
Old Apr 29, 2009 | 10:28 AM
I8ASTNG's Avatar
Tried a search, but came up with nothing. I noticed that my oil level sensor is leaking, any tips on removing the electrical connection? Anyone know what one of these sensors is worth?
Thanks!
Old Apr 29, 2009 | 11:21 AM
slingshot's Avatar
A new sensor would be around 30-40 bucks, I can't remember off the top of my head what I paid for it last year. All you need is either an open ended wrench, or crescent wrench to take it out of the oil pan, it is threaded into it. If it is not broken, I would remove it, clean the threads, and put a new o ring back in it. It really isn't worth buying a new one unless it is really broken.
Old Apr 29, 2009 | 11:28 AM
I8ASTNG's Avatar
It seems like it is leaking from the electrical connection, not where it screws into the oil pan, any trick to unplugging that connection without wrecking it?
Old Apr 29, 2009 | 06:32 PM
2001NBMZ28's Avatar
I've never replaced one on a LT1, but from the pic on shoebox's site looks like a standard 2 wire connector. Looks easy to just unplug and unscrew the sensor - I'd do it on your next oil change if it isn't leaking too bad. Don't know about the price, but the LS1 sensor is only about $23 GM list at a dealership.
Old May 6, 2009 | 12:41 PM
khojo16's Avatar
the clip for the plug is a little recessed into the actual sensor...u just need to take a small screwdriver and pop the clip up a little bit, and then u should be able to slide the plug out of the sensor...also, when i replaced mine the last time, i used a little RTV sealant on the threads and also around the outside of the sensor where it meets the pan...never had a leak after that
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
