Creaking noise and vibrating coming from the rear??
Old Apr 19, 2009 | 09:02 PM
sabedra211's Avatar
Everytime i turn a corner slow i can hear a creaking noise and the back vibrates and sometimes i can hear a low clunk clunk clunk. What do u guys think it causing this? how do i check my rear differential fluid? thanks.
Old Apr 19, 2009 | 09:29 PM
silentsprintero's Avatar
As proper maintenance you should buy a new rear end gasket. Just pull off the rear end gasket, let your fluid drain and look for an abnormal amount of metal shavings on the magnet on the back of the cover.
Seal it back up and fill with 2 quarts of your choice of rear end fluid and 1 bottle of GM LSD additive. Noise should be gone after that unless it is more suspension oriented. How many miles are on the car? Have you ever replaced any of the bushings?
Old Apr 20, 2009 | 01:19 AM
sabedra211's Avatar
the car has 163,xxx miles. I baught it like at 153,xxx miles and i havent replaced any bushings. and im not sure about the previous owners.
Old Apr 24, 2009 | 11:30 PM
sabedra211's Avatar
Alright well i finally got a chance to take a crack at this. So my fluid was very very dark. there are no metal shavings. Do i have to go 2 a dealer ship to buy the GM Rear diff. additive? And what weight of gear oil should i use?? And what should i do about about the dirty oil still on the differential? Name:  photo.jpg
karnykamaro
Feb 2, 2015 01:37 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
squarehead
Nov 21, 2014 08:02 PM
