Which springs to use for a big block 4th gen?
Old Mar 29, 2009 | 12:51 PM
Joes96z's Avatar
Which springs to use for a big block 4th gen? I have a the QA1 set-up with the 275 drag spring, but now I have a big block up front so those aren't going to work. Any one know which ones I should use or what size to get?
thanks, joe
Old Mar 31, 2009 | 01:13 PM
bluz28's Avatar
Lightbulb
You could get a set of BMR (SA001) Spring cups $59.95 pr..
Then you could use a set of 1LE front springs since they have a 360 lb.in. spring rate, or a set of SLP level II front springs with a 450 lb.in. spring rate.
You could use just about any lowering spring available for your car, but the spring rate would likely be higher than you would want.
MadMav
Feb 6, 2015 11:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
Skull Leader
Aug 10, 2002 11:01 AM
Eric H
Aug 10, 2002 06:39 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
