Differences in a 1995 4L60e and a 1997 4L60e?
Old Mar 28, 2009 | 05:49 PM
JooneJune's Avatar
Harness?
or are they both swap n play trans. I have a 95 going into a 97...
Old Mar 28, 2009 | 07:00 PM
12SCNDZ's Avatar
Harness?
It won't work. The 2 transmissions use a different 3-2 solenoid that ohm different. If you swap them, you'll throw it into fail safe and throw a 3-2 solenoid code.
I've seen "budget" shops attempt to swap the solenoid and harness only. The problem is, the 3-2 down valve, itself, is different. Swapping just the solenoid/harness will create a 3-2 runaway problem on a forced downshift.
BTW, the tail housings and speedometers are different, too.
Frank
CPT
Old Mar 28, 2009 | 07:37 PM
JooneJune's Avatar
are any trannys plug and play with a 97? (like a 96?)
Old Mar 28, 2009 | 09:04 PM
12SCNDZ's Avatar
'96 and '97 are interchangeable with no electrical modifications.
Frank
CPT
Old Mar 29, 2009 | 11:42 AM
JooneJune's Avatar
ty!!!!!
calaban
May 18, 2020 06:43 PM
79RS
Mar 24, 2015 09:30 PM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Jan 5, 2015 07:14 PM
joe777107
Dec 1, 2014 09:32 AM
