Dual stage questions
Old Jan 10, 2003 | 02:22 AM
ElkyRacer's Avatar
Would like to see some pictures of your dual stage system. What Ive got right now, 2 NX solinoids, and 2 compucar solinoids. Going to be buying a NX SX2 nozzle. Anyone heard any good or bad things about this nozzle?
Ive also heard fuel pressure drop is bad with a 2 stage kit. Is this so? Im only going to do a 75 out of the hole hooked to a WOT switch, and another 100 in the middle of 1st gear. Any pix or hints would be apreciated.
Thanks.
Kyle
Old Jan 10, 2003 | 11:29 PM
Derrick Redd's Avatar
Hey Kyle how much are the SX2 nozzles? Are you getting it directly from NX or another vendor? I'll probably be running the same setup you are thinking about.
Old Jan 11, 2003 | 02:18 PM
Z28ROC's Avatar
www.z28roc.cz28.com/en1.jpg
A dual stage would be easier on fuel pressure drop if anything.
But if your getting pressure drop at all that's not a good thing. Going by one of your previous posts, I would definately upgrade your pump before I hit the juice again.
Old Jan 15, 2003 | 03:39 AM
ElkyRacer's Avatar
Ive got that problem fixed! Fuel pump will be on the way soon.
Kyle
Old Jan 16, 2003 | 01:19 AM
ElkyRacer's Avatar
Anyone??
Old Jan 16, 2003 | 12:12 PM
LOL. I guess we will have to try it out ourselves since no one else is running a SX2.
Old Jan 16, 2003 | 02:45 PM
T/A lt1's Avatar
Try it out and post results so I can go get one if it's worth it That would be alot cheaper than buying a progressive controller.
DirtyDaveW
Mar 15, 2015 07:01 PM
Ws6Envy
Mar 3, 2015 04:31 PM
alphaauto
Jan 22, 2015 08:02 PM
importkiller94
Jan 17, 2015 09:03 PM
