Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
i have 2002 3.8 V6 camaro and want to step up the injectors
Old Feb 24, 2009 | 05:30 PM
hgifavor1004's Avatar
i want to know if i wanted to step up on my injectors. what do i go to. i have MSD coil pack, and MSD 8.8 lines, and K&N air filter and flow master exhaust.. So everything eles is stock i was looking on jegs and saw venom injectors for my car $160 24 pSI is thqat good for my car?? pr can i do better
Old Feb 25, 2009 | 12:24 AM
MikeGyver's Avatar
Why do you want bigger injectors? what is your current maximum injector duty cycle? if it's below 80% you dont need new injectors. running bigger injectors than you need is not only unnecissary, but it can be bad. Smaller injectors atomize fuel better and retain better "resolution" at low rpm.
Old Feb 28, 2009 | 03:08 PM
BlackBird97's Avatar
I don't believe you'll gain anything from bigger injectors considering your mods. I'd save your money and put it else were. Suspension? Or maybe even look into turbo? You'll find you're pretty limited with the V6. Trust me I've been there, first car was a 96 3.8 Camaro.
Old Feb 28, 2009 | 09:21 PM
mrmint69's Avatar
Unless you run N2O it would be a waste. Even then it would take a pretty big shot for it to be necessary.
birdblack
Dec 30, 2014 06:59 PM
ANDYZ28
Dec 29, 2014 09:13 PM
bernie1951
Dec 10, 2014 10:03 AM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
