Head studs or bolts?
Old Feb 19, 2009 | 07:33 PM
95z28_m6's Avatar
I was wondering how many of you +600hp turbo guys are running arp head bolts instead of studs. How much power/ boost can you make using bolts instead of studs? I would like to avoid the leaking stud issues if I can.
Old Feb 20, 2009 | 11:40 AM
RealQuick's Avatar
What is the leaking stud issue you are referring to? You put the same sealant on a stud that you would the bolt, and they both will seal fine. The stud is the way to go for clamping force (without stressing the head to threaded portion like a bolt).
Old Feb 20, 2009 | 01:24 PM
jsetzer's Avatar
We do have 5 bolts per cyl where the ls1 guys only have 4... that helps.
I run ARP BOLTS and was in the power range you are talking - I have run 5-7psi more than that since being on the dyno. No signs of leaking.
Also I run regular old felpro head gaskets.
If it matters I am in the upper 8:1 compression range too though.
Old Feb 20, 2009 | 04:07 PM
95z28_m6's Avatar
jsetzer How much boost are you running now?
Old Feb 20, 2009 | 04:44 PM
jsetzer's Avatar
Logs this morning show 19ish psi - Seen 23 a time or two, but that takes some really cold air and the wastegate never opening. Little 70 can't do that on a hot day.
Remember 19pounds on a t70 is vastly different than 19 on a 76+
Old Feb 21, 2009 | 08:57 PM
95z28_m6's Avatar
Mabey some of the guys with 76 or larger would be kind enough to tell if they run bolts or studs.
Old Feb 21, 2009 | 08:59 PM
1996camaroSSclone's Avatar
I ordered my PT88 a couple days ago and I'm going with arp head studs.
Old Feb 22, 2009 | 03:31 PM
RealQuick's Avatar
Go with head studs.
Old Mar 7, 2009 | 07:54 PM
97s10ondubs's Avatar
I have studs, pain in the *** to get the heads off in the car, have to pull the studs out, but they didn't leak.
Old Mar 7, 2009 | 11:32 PM
95z28_m6's Avatar
What did you use as thread sealant?
Old Mar 8, 2009 | 10:34 AM
Blownbird355's Avatar
arp or gm ptfe based sealant and small bars leak for good measure.
Yea just the regular permatex white thread sealant, I let them "dry" for 24 hours before I put coolant in. Coolant will wash the sealant off a little.
Old Mar 8, 2009 | 01:12 PM
rskrause's Avatar
Moderator
Bolts will work fine and make it easier to remove the heads in-car, which is a big advantage to me.
Rich
Old Mar 28, 2009 | 12:41 PM
94ttrim's Avatar
figured id bring back a somewhat old post instead of starting another. i plan on staying in the 500ish WHP area, 10-12psi at most (down the road), prolly gonna stay more in the 7-9psi range. would i be better off going with the bolts or the studs?
Old Mar 28, 2009 | 06:23 PM
bolts
