Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Digital or analog fp gauge
Old Feb 7, 2009 | 10:05 PM
600hplt1sm's Avatar
Hello, Im looking for opinions, I have a aem electrical FP gauge and it fluxuiates alot, I personally dont thing its very accurate, I used a gauge today off the schrader valve, it was just a small gauge i took off a FP regulator, but the pressure was steady, it wasent fluxuating at all, Which is more accurate, keep in mind im looking for a gauge for inside the car, Would a full sweep analog gauge be more accurate than a digital gauge
Old Feb 8, 2009 | 09:01 AM
NJ-LE's Avatar
600hplt1sm:
Check your wiring and connectors. Also, try to install the sensor on the supply line as far from the FP regulator as possible to minimize any pressure effects of the regulator loading and unloading. The isolators for analog pressure gauges are notorioius for unreliable readings and as you apparently are aware, direct connection fuel lines in the cockpit are dangerous. Electric it needs to be.
Old Feb 8, 2009 | 09:28 AM
Are you really asking about "analog" (sweep needle gauge face) vs "digital" (LED digital reading gauge face)? Or are you asking about "mechanical" (tube of fuel runs to the gauge and drives the needle on the Bourdon tube) vs. "electronic" (pressure transducer mounts in the fuel line, wires run to an electronic gauge)?
I've never tried a digital, but it would seem that the reading would "appear" to fluctuate more than the analog needle, because its reading out in a whole number that is changing rapidly in 1psi increments. The needle is going to be dampened slightly by the mass of the needle, and its tiny movements (still only 1psi) are not going to be perceptable. Comparing a digital reading to the super-tiny movements you would get in a very small gauge off a regulator would make the difference "appear" even larger.
How much fluctuation are you getting? What is the range of the pressure you are observing under steady-state condition?
Old Feb 8, 2009 | 11:03 AM
600hplt1sm's Avatar
Sorry I was asking about a needle sweep electric vs. a digital gauge. My fp with the aem gauge fluxuiates from 39 to 50 constantley, when i tried the small regulater gauge off the schrader valve to pressure stayed steady at 45-46.
Old Feb 8, 2009 | 02:05 PM
Where is the electronic pressure sensor mounted? Any chance its subject to excessive vibrations from the engine?
I have an AutoMeter analog/electronic gauge with the sensor mounted in a bung welded to the passenger side fuel rail, and don't have any problems with it. Pressure is rock steady. But I suspect some of the cheapie ricer gauge senders might be a bit more prone to problems with vibrations. I don't know anything about the AEM stuff.
Old Feb 8, 2009 | 04:51 PM
600hplt1sm's Avatar
Ok. The sensor is under the pcm, & now that i think about it before i unhooked it the sensor was just laying aganist the metal, when i put it back in i layed a towel down there and the sensor is laying on a towel now, when i started the car today and drove it around the block the gauge read steady so maybe it was the vibration, Oncew i get my pcm back i will test that theory & i already have a fitting with a gauge port going on my new parallel rails so this sensor will go to that port on the new setup
Formula Steve
Sep 19, 2023 08:31 AM
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
