Ls1 mass air flow question
Old Jan 25, 2009 | 11:24 AM
rcguy_77's Avatar
Will having a air filter connected directly to the mass air flow senser cause it not to read correctly .The car has problems idleing only when it is cold out for the first 10 minutes . Once the car gets warm it idles great . When it is warm out on its firts start of the day it idles like it should . The reason i am asking this question is while the car was runnig rough on a cold morning i unpluged the mass air flow and the car smoothed out but as soon as i connected back it went to running rough until the engine warmed up .
Any info would be appreciated , Thanks.
Old Jan 25, 2009 | 04:53 PM
2001NBMZ28's Avatar
Not sure what your setup is, air filter directly to the MAF? Where's the IAT sensor? Disconnecting the MAF is something to try during troubleshooting MAF codes like P0102, but you didn't mention a SES light.
Old Jan 25, 2009 | 05:39 PM
Kraest's Avatar
Retired
It shouldn't run rough like that with your setup. If it runs rough when cold and better when it warms up, it could be in the tune or the MAF. When it's cold and the oxygen sensors aren't being used to measure A/F, it uses a preset fuel table and the MAF together to adjust how much fuel to dump into the motor. When the engine warms up, the oxygen sensors become active and the motor then measures A/F by all three.
Most of the time, people have the opposite problem and the problem is their oxygen sensors.
What mods do you have? It is throwing any codes?
Mike
Old Jan 25, 2009 | 06:09 PM
rcguy_77's Avatar
Thanks for the reasponse , the IAT is between the MAF and the engine . There are no mods just a programer . I forgot to add that this was a v6 to ls1 swap . Thanks again.
Old Jan 25, 2009 | 06:49 PM
Kraest's Avatar
Retired
Good luck with that.
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
