Lean at WOT with open loop.....
Old Jan 22, 2009 | 10:42 PM
lt1street's Avatar
Im using tunning cat to tune an open loop with maf tune. My problem is im lean at wot from 5000 rpms up. i have made big changes in open loop afr table and maf tables, and see little change. fuel pressure is good at WOT 43.5ish. I just wound if im missing somthing? ve tables maybe ? not sure? thanks for the help.
Old Jan 23, 2009 | 08:50 AM
WS6T3RROR's Avatar
Injector duty cycle? If you change the maf tables copy them over to excel and change them by percent assuming you have logs of the airflow vs rpm from your wot runs. Graph the tables and make sure its smooth when you get done though should look like an exponential function for the most part.
Old Jan 23, 2009 | 10:20 AM
lt1street's Avatar
inj dc is 71.8%
Old Jan 24, 2009 | 07:40 PM
WS6T3RROR's Avatar
Post a log and your tune, dont think anybody is up for guessing games here.
Old Jan 25, 2009 | 01:53 PM
95Blackhawk's Avatar
On my first 383, I stayed with stock injectors because I was not intending to run high RPMs with it. On the wideband, it would start going lean at 5K RPM even though my injectors said I was at 80%.
Old Feb 4, 2009 | 09:45 AM
mzgp5x's Avatar
I had lean condition on a 97ss 383 D1 FI app @ high rpm. I found my fix from up-size of the fuel supply line. The stock line did not flow well even with a 255lph pump and K_Bell BAP. I went with 2 pumps and an up-size of the stock line (2 -6an socketless hose to -8an line with cooler to engine). The addition of the 2nd pump may be more than I needed, but, did it anyway, and, both are always on. I have plenty of fuel flow delivery with low line pressure head on the pumps. I did have alot of fuel return reulator failures of the diaphram. I recently modded the injector circuit to use a large size fuel reg. B.
Old Feb 7, 2009 | 02:34 AM
MikeGyver's Avatar
Originally Posted by lt1street
have made big changes in open loop afr table and maf tables...
TunerCATS?
You're using the wrong table.
Use the "%Change to Fuel/Air Ratio Vs. RPM at WOT" table.
Using the formula in: Help->Calibration Help->Tables->%Change to Fuel/Air Ratio Vs. RPM at WOT, you can set the AFR at WOT based on the corresponding temperature settings in the table: "%Change to Fuel/Air Ratio Vs. Cool. Temp. at WOT".
Old Feb 7, 2009 | 10:23 AM
WS6T3RROR's Avatar
Originally Posted by MikeGyver
TunerCATS?
Yeah.... pe tables... not consulted in open loop.
PopoFormula
Oct 12, 2015 04:19 PM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
Toxintwins
Sep 11, 2015 11:13 AM
