Whats Needed in a 650+hp FI Setup?
Ok,iam sure this has been discussed but i couldnt really find anything that fits me.Iam lookin to get 650+hp turbo setup.i have roughly 10k to spend for engine/turbo setup.can anyone lead me in the right direction for a parts list for this?wat does everyone think about eagle rods/crank?
ok so i was doing some research and mayb someone can go over this.
block: (PN off victory racing)
eagle forged crank PN-435337506000
eagle h beam rods PN-CRS6000B3D
diamonde forged pistons PN-11423
4 bolt splayed
heads:
trickflow p#-30400010
intake:
stock ported
cam:
custom turbo cam
fuel:
dual pump 60# injectors
(mayb to much for 650+hp??)
as far as turbo setup which turbo would you consider?is there kits out there that i should get?
4 bolt splayed
heads:
intake:
stock ported
cam:
custom turbo cam
fuel:
4 bolt splayed
heads:
intake:
stock ported
cam:
custom turbo cam
fuel:
4 bolt splayed
heads:
intake:
stock ported
cam:
custom turbo cam
fuel:
I make turbo setups, so feel free to shoot me an email to discuss some ideas for your goals ( jon@lt1boost.net)
Fuel system (sounds good... you can never have too much fuel system), heads, cam and intake look good. i didn't look up the rotating assembly, but a forged 355 or 383 with Eagle rods/crank will be fine, diamond pistons are good and splayed caps are good.
what ignition setup should i go with?just a box an stock opti?
If you ever want to put anything more sticky than a street tire. My friend had a T-trim on 16lbs and used to break the 10 bolt on the 1-2 shift on nittos on the street, broke 12 rears in total. He used to work for a place that installed gears so he would just put a new ring and pinion every time he broke it.
