Weird TransAm Factory Gears&Does anyone use 4.30's?
Old Dec 17, 2008 | 11:47 PM
TripleWhite's Avatar
Hey Im fairly new to the boards and have a couple of questions:
1-Does anyone use 4.30 gears with an A4?? Any info would be great ie traction,videos,times,etc
2-My 1995 Performace Package TransAm has an A4 but when I removed the old gears they were 3.42's this is the first time the rear end has been opened, I thought 3.23 (?) were availabe and the 3.42's were only for 6 speeds? I do have a 95 camaro m6 with confirmed 3.42's btw.
Old Dec 18, 2008 | 12:41 AM
Stl94LT1's Avatar
That's a whole lotta gear for a fairly stock A4 LT1.
We also have a triple white 95 TA, don't see too many of those.
Old Dec 18, 2008 | 01:26 AM
I love the triple whites, do you have any production numbers? oh and any ideas on cleaning the top?
Old Dec 18, 2008 | 08:43 AM
teke184's Avatar
someone obviously swapped rear ends...or at least gears.
or did you buy it new? cause that would be strange...VERY strange.
4.30s would be rediculous on anything shy of a fully built race car.
with a 6000rpm rev limiter, you'll be hitting overdrive at the end of the track...or darn close to it. compared to 3.42 where you'd be in the middle of 3rd with plenty of room to run.
would be fun on the street if you could hook up.
Old Dec 18, 2008 | 08:45 AM
JakeRobb's Avatar
Super Moderator
The sweet spot for a stockish A4 car is a 3.73:1 rear gear. 3.42 will be fun too, and you'll get better gas mileage.
Old Dec 18, 2008 | 11:37 AM
Stl94LT1's Avatar
I've searched for production numbers, but could never find. Have only seen one other triple white in this area. Ours has 155k miles and still runs strong.
We just use soap and water on our top, and still looks pretty good.
Old Dec 18, 2008 | 06:04 PM
Yeah, the previous owner was my father, no this was the stock rear end, thats why I was so surprised. And 4.30s I decided to go with I wanted a pull or no traction, the TransAm will not be a daily.
Old Dec 18, 2008 | 06:07 PM
Oh and Im superchargin my t/a I was told this was a cam meant for a nitrous/blower combo.
Old Dec 19, 2008 | 03:21 PM
anyone else?
Old Dec 19, 2008 | 08:03 PM
Kevin Blown 95 TA's Avatar
Good luck with that setup, LOL.
Old Dec 20, 2008 | 08:36 AM
How is that, you know 4.30s would be fun, I really dont care if the driveability goes to ****, I have another 95 vert....daily 6 speed z28 any day over an 95 Vert A4 T/a
Old Dec 20, 2008 | 10:36 AM
What was the tooth count on the ring and pinion?
Old Dec 21, 2008 | 03:13 AM
I will have to check tomorrow.
Old Dec 21, 2008 | 11:17 AM
If you didn't count the teeth, how did you determine they were 3.42 gears?
Was the speedo accurate in the car? Did you check the PCM to see what rear axle ratio it was calibrated for?
Old Dec 21, 2008 | 01:27 PM
RUNMYTA's Avatar
Back in 1995, I was able to special order my rear with GM 3:42 gears for my T/A A4. Basically, all it was, was the "performance axle" option that came with the M6's.
