Need Pics of Fogger on LT1 intake
Old Jan 5, 2003 | 06:08 PM
FLyinlow89's Avatar
Hey guys. Can you please post pics of fogger set up on LT1 intake.....The more the marrier. Id appreciate it.
Old Jan 6, 2003 | 06:54 AM
George Debski's Avatar
http://www.cadwiz.net/cherrybomb/Tec...s/nitrous.html
Old Jan 6, 2003 | 11:31 AM
Grover's Avatar
Question Nozzle Orientation
George,
Does it matter what the orientation of the NX Shark nozzles are mounted in? Looking at the nozzle I thought it would be best to mount it horizontally due to the angle cuts on the nozzle to allow for a better spray pattern into the throttle body. But I would really like to mount it vertically from underneath into the Fenco elbow between my MAF and TB, and I see that is the orientation that you have your nozzles mounted.
Old Jan 6, 2003 | 05:27 PM
FLyinlow89's Avatar
thanx for the response George but I need pics of FOGGER SET UPS not fogger nozzles. I appreciate it tho
Old Jan 6, 2003 | 07:00 PM
LT1Z28's Avatar
I am presuiming you mean a direct port setup right well here yah go
http://www.rufidlz.cz28.com/383NOS.htm
This is another setup which i sold recently
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1872237490
Old Jan 7, 2003 | 07:57 PM
FLyinlow89's Avatar
Originally posted by LT1Z28
[B]I am presuiming you mean a direct port setup right well here yah go
well ya. But me saying "Fogger set up" means the same without sounding like I just watched The Fast And The Furious
Old Jan 7, 2003 | 08:06 PM
LT1Z28's Avatar
True but not everyone here truly knows what a fogger setup is. There arent that many of us running around anyways later hope the pics helped.
Old Jan 7, 2003 | 08:09 PM
FLyinlow89's Avatar
Yup..they did help...thanx man
Old Jan 9, 2003 | 02:32 AM
Victory Racing's Avatar
Here are the pics from my NX Direct Port that I just finished a few months back.
http://community.webshots.com/photo/...54713681olGzaF
http://community.webshots.com/album/52571171OGGcqh
Old Jan 9, 2003 | 08:07 PM
JWINN's Avatar
My intake was plumbed and flowed by Jeff Prock at Applied Nitrous Tech. Below is two pic's of a NOS Pro Race direct port annualar nozzle race kit on a LT4 intake.
First pic shows how the kit was custome bent up:
http://www.gofastzone.com/members/Th.../mvc-377s1.jpg
Second pic shows how we where able to use the NOS stainless annular nozzle, Special bungs where welded to the runners. This kit is setup to shot anywhere from 100hp to 500hp:
http://www.gofastzone.com/members/Th.../mvc-378s1.jpg
Take the guess work out of what jet pattern and or fuel pressure to run and have Applied flow your nitrous kit. Tellwhat power want toget out of your kit and he will give you jet pattern,fuel psi and timming.
Jeff Prock is the top nitrous tuner in the nation. You want to go fast with nitrous have Applied set ya up.
www.appliednitroustechnology.com
Good Luck!
Jim Winn
Old Feb 16, 2003 | 05:35 PM
94droptopz's Avatar
lt1z28- im wondering whats the real difference between your fogger setup and the shark nozzle? you have it running through a rail to the each cylinder but it still distributes it to the first 2 cylinders first correct? or does it build pressure and deliver it evenly? im asking cause im fixing to install a nitrous setup and im not sure which way to go.thanks
Rob
HectorM52
Jun 23, 2016 08:42 PM
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
95chwagon
Jan 13, 2015 09:19 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
