bleeding ls1 coolant system
Old Dec 13, 2008 | 06:06 PM
teke184's Avatar
there are no bleed screws like on the LT1 correct?
just bring it up to temp a few times and top off the fluid?
installed a mez EWP this weekend. doesn't seem to overheat so i think i got the air out.
just looking for a quick confirmation.
Old Dec 13, 2008 | 06:10 PM
Marc 85Z28's Avatar
Easiest way is to loosen one of the cylinder head coolant crossovers while you fill at the radiator, like a bleeder. Keep adding until coolant pours out from the crossover, then retorque. Top off coolant in radiator and overflow and you're done!
Old Dec 15, 2008 | 06:52 AM
teke184's Avatar
well sofar i've just done the "warm up...cool down...top off" schedule.
so far i've done it 3 times and the temp has never gone high. granted its the crappy iddiot light guage in the 99+ cars.
but still.
and since it's and EWP i can just turn the ign on and cycle it.
sofar so good...stays cool and the car seems a bit more peppy after freeing up the engine of the pump drag.
not that you can truely feel ~10hp
but the drop in drag seems to make the engine spin faster in neutral
Rod Bender
Nov 7, 2023 02:30 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Biggiebound
Apr 21, 2015 11:28 PM
Sandersen511
Jan 13, 2015 03:49 PM
