Dyno Numbers!
Old Dec 12, 2008 | 10:45 PM
jchevy's Avatar
Dyno Numbers!
Dynoed the car today at 15 PSI.
586 hp 607 Tq
Im pretty happy with it.
Have a really weird fuel issue around 4500 rpm that was there on every pull. Goes lean then rich, then back to where it should be by 5000 rpm. Couldnt get it tuned out no matter what. I think thats hurting the power and might be able to break 600 at the wheels with some more time on the dyno. Had to cut the time short because it was getting late.
Old Dec 12, 2008 | 11:41 PM
firetird's Avatar
awesome, man.. congrats! That thing must be a blast to drive with no lag and that much torque!
Old Dec 13, 2008 | 02:58 PM
slomarao's Avatar
nice job, what kind of setup are you running?
Old Dec 13, 2008 | 06:19 PM
RealQuick's Avatar
Nice #'s.
Old Dec 13, 2008 | 10:00 PM
jchevy's Avatar
Im using log manifolds very very similar to RealQuicks kit.
Old Dec 15, 2008 | 08:15 AM
jsetzer's Avatar
Stockish heads?
Looks good. I'm glad to see someone else with similar numbers to me. Makes me feel like mines not too far off base.
Old Dec 15, 2008 | 08:47 AM
RealQuick's Avatar
Originally Posted by jsetzer
Stockish heads?
Looks like Lloyd Elliott ported stockers?
Old Dec 15, 2008 | 09:02 AM
92LT1RS's Avatar
Looking forward to hearing more about your fuel issue and if you get it figured out. I'm going to be running 60# injectors on dual in-tanks as well and should be putting out similar power.
Old Dec 15, 2008 | 01:33 PM
jsetzer's Avatar
That could be my heads or something far more extreme
Mine are in the area of LE1s.
Old Dec 15, 2008 | 05:33 PM
jchevy's Avatar
Im running the LE1 heads with the larger valves, so nothing crazy.
It was late and didnt have a lot of time on the dyno, didnt get to play with the timing at all. Car also seemed to max out about 5500 rpm which I thought was low. My cam should be good to about 6200. Im wondering if the turbo is a little undersized.
Old Dec 16, 2008 | 02:54 PM
jsetzer's Avatar
Oops, I read t76... you have a 67. Possible My MP t70 is falling off up top, but I think the t70 is actually closer to a 60-1 or something. I think the wheel is in the ballpark of 63mm.
But that still doesn't seem bad. I made 640# but lost something like 200# between 5 and 6k. My peak HP was really low.
HarleyZ28
Oct 5, 2015 06:23 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
BLK1997Z28
May 7, 2015 03:01 PM
racecarz28
Mar 30, 2015 09:55 PM
Joe Brodman
Jul 24, 2002 05:24 AM
