cams
Old Jan 5, 2003 | 01:46 PM
98whiteZ28's Avatar
cams
alright i'm lookin at seriously gettin a new cam for my car to replace that stock one and i was lookin at comp cams but any other suggestions would help and how long will the installation take too?
98 white Z28
Stealth air induction, grenatelli 85mm M.A.F
borla exhaust Ls6 intake manifold
tinted windows an clear corners
Old Jan 5, 2003 | 02:52 PM
kahouna23's Avatar
First off, I drive a V-6, but the wife has an SS. I have a 268 duration Comp Cam in my six, and I must say it's worth the money. They're fairly simple to install. I had to remove mine recently to avoid problems at the dealer with voiding the warranty, and I had it out in around 2 hours. Install is around the same time frame. If you're wanting a lopy idle a 268 is the way to go. This one also works well with stock gearing like 3.40 or 4.10's. I believe the 270 duration with a .470 lift is the biggest cam you can have with a stock converter. Anything higher like a 280 you need to get a new torque converter. Hope I was of some help, even though I drive a sixer..
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
