Front shock insulator
Old Dec 3, 2008 | 11:48 AM
GMCAMARO's Avatar
Do I need to include these, if I am replacing my shocks with Edelbrock shocks? The pictures sort of suggests yes, but the text sort of suggest no.
Old Dec 3, 2008 | 10:31 PM
How about some basic info, like the year of the car. They built 4 different generations of F-Bodys over a 36 year period.
Why not add a "signature" with basic info about your car - year, model, engine, tranny and any major mods. That way when you ask a question, people will be able to help you.
Old Dec 4, 2008 | 06:24 AM
GMCAMARO's Avatar
Sorry.
99 SS, M6.
The insulator is the small piece between the spring and the shock upper mount.
Old Dec 4, 2008 | 02:05 PM
ACE1252's Avatar
The small rubber "wedge" on the top of the upper mount?
Old Dec 4, 2008 | 06:22 PM
GMCAMARO's Avatar
On top of the spring between the upper mount and the spring. It is small #52 on GM's picture.
Edelbrock claimed it is not required, case close, thank you.
Old Dec 4, 2008 | 07:04 PM
ACE1252's Avatar
If it's what I think it is....then I think it helps to prevent water from moving down into area where the top of the shock is bolted to the mount.
It didn't really help mine from rusting together.
Old Dec 6, 2008 | 01:06 PM
The diagram looks like it has the parts out of order.
http://shbox.com/1/front_suspension.jpg
On mine the "dogbone" (#52 ??) insert was located on top of the spring/shock seat, and helped distribute the load. I suspect leaving that part out might lead to premature tearing of the rubber around the metal ferrule in the upper spring/shock seat. When I installed my QA1's, I used all of the stock pieces.
Old Dec 6, 2008 | 03:47 PM
bluz28's Avatar
Lightbulb
Everything from the upper mount on up you do need with the edelbrock IAS front shock/spring combo.
I have them on my car.
And Yeah, that black And white parts break down photo doesn't help at all, it's rather confusing.
Old Dec 7, 2008 | 12:24 PM
chevelles101's Avatar
Let me know how those edelbrock's work out for you. I've been interested in how they perform.
RUENUF
Mar 13, 2016 03:39 PM
Fastbird93
Jun 3, 2015 05:56 AM
Boss002
May 20, 2015 12:55 PM
BLK1997Z28
May 1, 2015 12:23 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
