Charging problem
Old Nov 28, 2008 | 11:08 AM
Nicuda's Avatar
Charging problem
How's everyone doing?? My son just bought a 95 Z28. Had it for 2 days and had to replace the battery and alternator due to charging problems. After some troubleshooting, I found that after the car gets warmed up the battery only gets @10 volts (gauge goes into the RED discharge area). If you break off idle it goes to @14.4 volts, let it back to idle it goes back in the red. The idle is @900rpm (according to factory tach). Since it is a used car I really dont know too much about it. Was told the opti-spark was replaced, a new tranny was installed with a stall convertor. The AIR pump was removed, but they removed the fuses and relay for it. The pulley on the original alt. is slightly larger then the one that was bought. My son swapped out the pulleys, keeping the one that came with the car. It's supposed to have underdrive pulleys,.
Will be starting to look over everything this weekend, any advice would be greatly appreciated, since I'am not that great with electrics!!!!
Old Nov 28, 2008 | 12:38 PM
scooters97ss's Avatar
Sounds like the pulley is probably the culprit. Check the alt output with a good meter and if it is too low use the pulley that came with the replacement alt and see where that leaves you.
Old Dec 1, 2008 | 07:29 PM
wbacall's Avatar
I have the same problem & suspect the Bosch rebuilt alternator. Bosch techline said the problem is "Normal" I will try a Delco rebuild as soon as I can.
Old Dec 2, 2008 | 01:37 AM
ACE1252's Avatar
I would put the original pulley back on the alternator(ie the stock pulley). I'm not a fan of underdrive pulleys. Since the voltage gets normal off idle I'm fairly certain that this is your problem. If the problem is not fixed after the swap, take the alternator back to the place of purchase for testing or exchange.
Old Dec 10, 2008 | 08:06 PM
wbacall's Avatar
I replaced the alternator with a Delco rebuilt and it seems to be ok so far.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
