Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Pump up your LS1 fuel pump - LS1 Hot Wire Kits $39.99
Old Nov 17, 2008 | 10:31 AM
Full Throttle Speed's Avatar
Fuel Pump Hot Wire Kit for 99-02 Firebird and Camaro
Fits cars with plastic tank only!
Voltage is what makes your fuel pump, pump. More voltage = more fuel, less voltage = less fuel. In our testing a change from 13 to 12 volts on a Walbro pump will reduce fuel pump delivery by 20%! The stock wiring is barely good enough for the stock pump but when you add a high performance pump it is not up to the task since current demands go up quite a bit and in some cases they double. Enter our Hot Wire Kit. We pull the power from the back of the alternator where voltage is highest and then route it to the back of the car using heavy duty 10 gauge wire for maximum power and minimum drop. We also use factory style sealed connectors and a weather sealed 40 amp relay for "plug and play", no wire cutting installation. We also provide for additional ground connections for maximum performance since that needs an upgrade as well. Wire ties are provided so it is easy to secure the new harness to the car safely. A connector is installed into the main power cable so give an easy install point for fuel pump voltage boosters like the ones made by Kenne Bell and MSD.
Made in U.S.A. By ISO9001 certified harness builder to OEM specs. One year no hassle warranty! If you are not happy, just return it for a full refund within the first year even if you use it.
Call or order online!
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Skull Leader
Aug 10, 2002 11:01 AM
