all bad = not good
Old Nov 12, 2008 | 07:35 PM
camaroLevi's Avatar
Angry all bad = not good
well today after droppin my friend off from work then coming outside from his house, went to try and start my car...this time it didnt do ANYTHING!!.. not even a crank....so i had to tow it alll the way back to pep boys and im awaiting diagnosis as of now......and whats weird is the tow guy was all like hey let me look under ur hood so i showed him where the relays were that pep boys took out from the fuse box,,,..he starts exchangin the fan relay with the fuel/ ignition and it started once then not again but he said they screwed me for 759.00 ...whats up with this freaking car???? im soooooooooooooooooooooooooooooooooo desperate to figure this out..anyone??
Old Nov 13, 2008 | 06:40 PM
camaroLevi's Avatar
ughh
well anywho i got it back today...they said it was a starter relay and the dont know what is tripping my relays sooo i took my stereo amp/amps out so that theres no mis-caculating a relay gone bad again...any input anyone?
Old Nov 13, 2008 | 07:40 PM
Angelis83LT's Avatar
well.. are ALL the relays tripping? Generally only reason they will flop off and not work i either a short in the harness, a bad ground. Or a short in the part they go to.... And since they are not ALL on the same harness, it should be just a few popping off, unless it is a ground... I think anyhow...Basically they do not know because they probably did not test any of the wire connections.
grabbem88
Feb 13, 2015 03:09 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
mattszm6
Dec 14, 2014 07:09 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
