What header flanges?
Old Nov 12, 2008 | 11:54 AM
jay_rich's Avatar
Hey I was just wondering what header flanges you guys use on your header builds. I was planing on using regualer SBC circles, will they work? Could I use 1 3/4 or would I need to use 1 5/8?
This will be on LE2 heads.
Jay
Old Nov 12, 2008 | 08:23 PM
evilundisguised's Avatar
Jay
Most or all of LT1 headers I have seen use round ports. Wouldn't you pick the size based on what size primaries you're using? Or is primary size part of the question?
Old Nov 12, 2008 | 08:35 PM
jay_rich's Avatar
No i was asking about which size bc i heard 1 3/4 ovels wonts work on LT1s. I found a set of 1 3/4 rectrangle and they work (as the headers I have on there now are rectangle.
Jay
Old Nov 12, 2008 | 09:16 PM
crazycat's Avatar
I am using 1 5/8 round port on my new set up. 76mm t6 turbo
Old Nov 28, 2008 | 09:32 PM
evilawd4g63's Avatar
i dont know how to put pics on here or id show u mine but i had a set laser cut to match a corvette gasket. ebay used to sell d port flanges for $75.00/set
Old Nov 29, 2008 | 07:52 PM
RealQuick's Avatar
1 3/4" oval are fine as long as the machine shop making the flanges don't mess up and make it too big (like I had happen to me).
Old Nov 29, 2008 | 09:12 PM
Z8'S's Avatar
I digitized my exhaust ports and bolt locations and machined them myself from 1/2 plate for my Twin Turbo setup.
Old Nov 30, 2008 | 08:46 PM
DirtyDaveW's Avatar
Jon, I'd like to see you or one of these other enterprising guys use these flanges so you could make a primary as big as you want and we could still bolt them to the heads.
http://www.stahlheaders.com/af.htm
Old Dec 1, 2008 | 01:13 AM
reamo04's Avatar
in FI though, you dont really need BIG primary's
Old Dec 1, 2008 | 04:04 AM
DirtyDaveW's Avatar
What I'm really after with the alternative flange is to get the bolts away from the primary tube so you can get a socket on them more easily.
Old Dec 1, 2008 | 12:01 PM
reamo04's Avatar
on my first turbo kit using some headers i bought from realquick, they had an extension on them to get the bolts out further. However, I could not use regular header bolts, i had to go to the hardware store and buy bolts since they needed to be that much longer. Still worked fine though.
Old Dec 1, 2008 | 12:09 PM
how bout these http://cgi.ebay.com/ebaymotors/D-por...spagenameZWD1V
Old Dec 1, 2008 | 12:23 PM
RealQuick's Avatar
Dave, I build all my kits with the assumption that the stage 8 header bolts will be used. These bolts have the allen wrench hole in the center, this way you can use a nice 1/4" drive ratchet and allen head socket. Makes life easier than using a wrench... plus you dont need to fit a socket around the outside of bolt head (where there is no room).
Old Dec 1, 2008 | 01:05 PM
DirtyDaveW's Avatar
I used those initially but getting an allen wrench of the proper length/shortness had been problematic. I now use ARP 12point header bolts and they work well though I still have to use about 3 Stage 8's. How's life Jon!? Hope things are going well.
Old Dec 1, 2008 | 01:07 PM
RealQuick's Avatar
Dave, things are good! Hope those new heads you got will make some power!
