Are there any power sources that...
Old Jan 3, 2003 | 03:56 PM
silver97Z's Avatar
Question Are there any power sources that...
I'm going to be installing a power antenna sometime in the near future and was wondering if there are any power sources that only have power when the FM/AM radio is on...something that has no power if the CD player is in use? That way, when I put a CD in and the FM/AM radio goes off, the antenna will go down.
If not, I guess my only other option would be to install a switch somewhere.
Old Jan 3, 2003 | 04:21 PM
stik6shift98's Avatar
speak of the devil
i just did that....power antenna
do u have a stock cd player in your car????
i dont and mine had a wire in the back of the cd player that i hooked it up to...
let me know i can guide u thru it
Old Jan 3, 2003 | 05:27 PM
silver97Z's Avatar
Thumbs up
Yeah, I do have a stock CD player, but I would think the wiring should still be similar.
Anyway, shoot me an e-mail or reply here and let me know where you connected your power for the antenna, I'd really appreciate it. Everything else looks like it should be pretty easy, except I still have to figure out how to connect the antenna wire that came with the antenna and the stock antenna wire together...they both have the same connector on the end so I can't just plug them together...can that wire be spliced together?
And does your antenna go down when you listen to a CD and then back up when you listen to the radio? That's really what I want mine to do.
Thanks!!
Brian
Old Jan 3, 2003 | 10:26 PM
bout antnna wire..... u need to get female female plug thing...cuz both of yours are males right....
antenna up down......im not sure ill check for you
i think u cant do that...
NewsBot
May 15, 2015 10:10 AM
XtremeLt1
Sep 13, 2002 08:50 PM
StngStlkr
Sep 6, 2002 05:47 PM
