Heater Not Working..
Old Nov 10, 2008 | 12:54 AM
JAG05's Avatar
So my heater isnt working good. I took my A/C off awhile back and the heater hasnt worked since. I left the AC lines open so the lines are just sitting there open. Could there be cold air getting in through those lines and making the the heater blow cold?
Old Nov 10, 2008 | 04:43 AM
maverickmk's Avatar
AC and heat are two separate things. Your heater core is probably clogged. Disconnect the 2 hoses that runs to the firewall/heater core and back to the water pump from the water pump, then using a low pressure water hose on one of those hoses flush it out.
Old Nov 10, 2008 | 07:29 AM
brickonwheels's Avatar
I did what maverick is suggesting a couple weeks back and my heater has never blown so hot. I am in love with my car all over again.
Old Nov 10, 2008 | 03:10 PM
JAG05's Avatar
Ok thanks guys. Also what size is the threads on the A/C lines so I can buy some caps to cap off the ends...
Old Nov 10, 2008 | 07:13 PM
maverickmk's Avatar
DO NOT remove the ac lines - only the coolant lines, these are 2 completely different lines/hoses, one carries coolant from the motor/water pump and the other carries refridgement/freon, if you open up the ac lines you have a mess - only the coolant lines
Old Nov 10, 2008 | 07:55 PM
JAG05's Avatar
Ive already taken the AC off of my car. Now I just have open lines and was wanting to put something over them to cover them up to keep trash out. So what size are the threads on the line that go into the compressor?
Old Nov 10, 2008 | 09:31 PM
Godly96_SS_Here's Avatar
wont a clogged heater core cause the car to overheat?
Old Nov 10, 2008 | 10:25 PM
No. The heater circuit is just another route for coolant. It does not block function between the pump, engine and radiator.
Old Nov 11, 2008 | 12:28 PM
94arcticwhiteM6's Avatar
x2
Old Nov 11, 2008 | 10:23 PM
fastdan's Avatar
A clogged Heater Core can cause a Car to overheat.
Dan
Old Nov 11, 2008 | 10:41 PM
Green96Z's Avatar
Dan
No it won't. If you capped off the two heater hose connections at the WP, the engine would not overheat.
Old Nov 13, 2008 | 08:38 PM
JAG05's Avatar
Anybody know the tread size on the ac lines so I can cap them off?
Old Nov 25, 2008 | 05:17 PM
JAG05's Avatar
Ok flushed the heater core and heater works awesome now. Thanks for the help!
Also does anyone know the thread size on the A/C lines??
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jan 23, 2015 01:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
