SLP Hurst shifter v/s stock unit
Old Nov 7, 2008 | 02:59 PM
Camm95Z28's Avatar
Hello there. Does the SLP Hurst shifter have any shorter throw length than the factory installed shifter? I imagine it would be notchier but side by side to me both units look the same. Thanks
Old Nov 7, 2008 | 03:51 PM
6SpdLT1Z's Avatar
Pivot point is higher and I believe the shifter stick is also shorter. So yeah. Hurst + Lou's Short Stick is, IMO (from what I've tried, short stick, pro 5.0, stock, and hurst) the best f-body shifter out there.
Old Nov 10, 2008 | 07:11 AM
teke184's Avatar
from the factory...both shifters have the same stick
the hurst option has shorter throws
the stock unit has a stamped steel base, while the hurst has a billet steel (maybe alum..not sure).
i've measured the throw difference on my setup.
stock shifter and stick from 1st to 2nd gear was something like 8" of travel. hurst with the stock stick was something like 6" of travel. and with a Lou's Short Stick installed on the Hurst...the throws were 3.5"
HUGE difference. i can shift with my wrist, never taking my elbow off the center console.
Old Nov 11, 2008 | 02:41 PM
OBE1 95Z28's Avatar
Stock shifter also has the rubber isolator that makes shifting feel sloppy.
Old Nov 11, 2008 | 06:30 PM
The rubber isolator is in the base of the stick. The factory Hurst uses the stock stick with the big rubber bushing.
I had a factory Hurst that I picked up with a T56 from a 97 SS convertible. Side-by-side with my old Hurst Competition Plus, there was no comparison. The base of the factory Hurst was thnner material the the "real" Hurst. I don't think it was "billet". Neither was the original Hurst. Hurst later came out with a "Billet Plus". That one might have actually been "billet". Factory used the sloppy stock stick. Real Hurst had a solid metal stick, bolted directly to the shifter.
I sold both of them. Pro 5.0 seemed a lot better.
Old Nov 12, 2008 | 02:04 PM
powerslide350's Avatar
I swapped from non hust to oe option Hurst and it actually made my shifts harder due to how tight that thing was. May have just been the one I bought (used), But I could shift faster with the loose stocker.
Old Nov 12, 2008 | 05:55 PM
96 Z 28's Avatar
I'd have to 3rd the SLP Hurst w/ Lou's Short Stick
I have that exact combo as well... and yup shifting is quick, easy, and without a doubt much much less travel
I'd also recommend changing the shift **** too, the big ol cue ball is really also a disaster. I went with the SLP Leather ****, and couldn't be happier although you may want to look around as to what fit's you hand the best. Although I doubt you'll be disappointing with the SLP ****
Old Nov 12, 2008 | 09:23 PM
Green96Z's Avatar
I have the same ****, very nice feel to it. Except mine sits on a B&M Ripper.
Old Nov 13, 2008 | 08:40 AM
6SpdLT1Z's Avatar
I also have the same combo expect the hurst classic white shift ball w/ 6 speed pattern
Old Nov 17, 2008 | 11:45 AM
TBSPW's Avatar
SLP Hurst w/ Lou's Short Stick...VERY NICE!!!
Old Nov 17, 2008 | 01:32 PM
teke184's Avatar
slp hurst, LSS, MBA shift ****....so i'm even shorter
i personally like the feel of the round ****, and its black to match my interior with a Z28 engraving.
the MBA **** is designed to actually reduce the height of the **** location, they started the threads deeper in the ball.
Old Nov 17, 2008 | 05:56 PM
96 Z 28's Avatar
Only issue is MBA is long gone John closed shop about 2-3 years ago, and I bet finding an MBA **** would be very expensive, if you could find one at all
Old Nov 18, 2008 | 07:32 AM
teke184's Avatar
yeah i know...i've had the **** for nearly 7yrs.
on my old LT1 with the LSS...it actually put the **** TOO LOW, it would sit about 1/16" away from the rear edge of the console when in 2/4/6th gear.
but the ls1 console is better
Jazsun
Dec 29, 2014 12:14 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
slocody
Feb 10, 2003 01:04 PM
Carguy00
Aug 6, 2002 10:25 PM
