Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Car misses/cuts out at high rpm!!!!!
Old Oct 28, 2008 | 02:06 PM
Godly96_SS_Here's Avatar
Mods in sig....
Sometimes this happens and sometimes it doesnt; at WOT about 5-6k RPM my car feels like it is cutting fuel? it sounds like a revlimit tapping! it stays that way until it shifts and lowers the rpm's lower than 5k but it doesnt matter what gear i'm in just if the rpm's are high enough. sorry if this isnt much info but its really hard to describe, i was tinking the injectors need a cleaning? or my fuel pump is failing? other times the car runs out great with no hesitation at all!
Old Oct 28, 2008 | 02:30 PM
mrmint69's Avatar
Run it with the fuel pressure gauge hooked up and see what happens to the pressure at higher rpm's. Change the fuel filter if its old also.
Old Oct 28, 2008 | 02:31 PM
seawolf06's Avatar
Check your fuel pressure, could be the pump cutting out or even the regulator.
Old Oct 28, 2008 | 04:27 PM
I will try that, where can i find a gauge that i can run in to the car while driving? what should the presure be at?
also, filter has about 3,500 miles on it. think i should change it?
Old Oct 28, 2008 | 11:35 PM
Fatdog2's Avatar
Might change the coil wire and see if that helps.I don't care if you replaced it 6 months ago.My02.
Old Oct 29, 2008 | 12:37 AM
mrmint69's Avatar
I bought one at the local auto parts store for $25. It has a flexible hose about 16" long so I can run it up to the windshield and I use the wiper to hold it in place. You want it to be in the high 30's and 40's at wot.
Old Oct 29, 2008 | 04:07 PM
Why don't you care? LOL JK! It honestly feels like a fuel issue, but I will keep that in mind. Thanks!
Old Oct 29, 2008 | 05:46 PM
Kevin Blown 95 TA's Avatar
If it was the coil wire, then engine load, not necessarily rpm, might make it harder for the plug to fire, then the voltage tries to leak out the plug wires to ground. So higher gear = more load @ lower rpm. So it would vary the rpm at different gears or engine load (like going up a hill). Same with a bad coil, although heat can also make the coil miss if it is bad internally. You could have a weak coil that can't fire a large plug gap, too.
Another thing is heat range of your plugs - they can miss if they are too hot, but that depends on your power level, and NGK have a wide heat range, so it might not be that. Also, if nothing else works, look at the plugs. If you have a cracked one, it can act up at a certain load and be hard to find.
Do the fuel check first though - that is easiest, and we all know the pumps go bad from old age.
Old Nov 22, 2008 | 11:52 PM
Fatdog2's Avatar
I replace my coil wire every time I feel the car ain't runnin like it should.Just me I guess.
97SSdude
Dec 31, 2014 07:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
