Transmission Slipping? Went from shifting perfect to stalling?
The car was shifting perfect and all of a sudden I take off from a stop sign and it acts like it would if I were in a manual riding the clutch. When I get up to speed around 55 the rpms do not drop, there is now no difference between Overdrive and drive, the rpms just stay up while I have the gas pedal in but when I let off they drop to idle.
I forgot to mention that the fluid level is always perfect and it was rebuilt maybe 30,000 miles ago according to the person I bought it from. I did notice that they left the cover off of the torque converter and flywheel, and I was wondering, is the torque converter supposed to spin while sitting in park?
Sounds like some serious slipping issues. What condition is the fluid in? Is it still red/pink? Does it have a burnt smell?
Yes, the converter will always turn, when the engine is running.
Frank
CPT
Frank
CPT
This is an educated guess but maybe in the rebuild they put in a higher stall converter then stock and your fluid is getting too hot?
I have a similar slip due to a high stall converter but only when I'm stopped and man does it grab hard once it engages lol.
Good luck
Good luck
You said you took it back out and it did fine again? I would say your going into limp mode . I would suggest scanning for codes first
Frank at PerformaBuilt
The fluid has a small amount of ****? You cant see it immediately but once you let it soak into a paper towel you can see a smutty residue separate from it. The fluid is now a dark crimson color and I can't tell if it has a burnt smell. It has slipped and went back to normal twice now. Strangely it happened once I got to the very same stop sign??
Sorry ittook me so long to reply; I scanned it and it finally threw a code 81 "QDM or Second shift solenoid fault." Is the QDM or Second shift solenoid something that can be changed without opening the transmission?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
