HELP! Dunno what's wrong
Old Jan 1, 2003 | 08:33 PM
WheelmanZ28's Avatar
I just finished hooking up my JBL Tweeters to the front of my Rockford Fosgate speakers. i also put the same Rockfor Fosgates in the rear also with bass blockers. So I'm out driving, and the bass on my two Jensen 10"s starts to sound a little faded. They are powered by a Pioneer 760 Watt amp. All of a sudden the bass just goes dead. Im like, WTF?? but im not that concerned cuz i thought it was just a fuse. I get out and check, the fuse is just fine Now I'm worried. I check over all the wiring to the amp, everything is still connected properly. The Amp didn't get hot, and it doesnt smell fried.
Anyone have any ideas? Please don't tell me i blew something!
Thanx all.
Old Jan 3, 2003 | 01:02 AM
knightbird1's Avatar
I would check and see if the ground cable is properly grounded.
Old Jan 3, 2003 | 09:20 AM
CeeBee94Z's Avatar
I would have to say that it is probably ground related as well... I doubt that you blew anything...check grounds first
Old Jan 4, 2003 | 12:52 AM
Took your guys advice and tried to run the ground to one of the factory grounds. Still no go. The amp lights up and everything like it's supposedly working, but i get nothing out of the subs. I even checked the 25 fuses on the amp and the 30 fuse on the wire leading to the battery terminal. Both appear to be fine. Could something be wrong internally with the Amp? Or is it possible that both subs went out within a few seconds of each other? could a connection at the head unit be bad all of a sudden? PLEASE HELP! Thanx
Old Jan 4, 2003 | 01:28 AM
CalPoly96Z's Avatar
You should check the RCA cables and make sure that they didn't burn out on you
Old Jan 4, 2003 | 02:01 AM
stik6shift98's Avatar
hmmmm. thats odd
ask a local best buy or circuit city to check it out......just tell them some other location installed it for u and u were around here and u just want to see whats up with it that way u dont have to pay jacksh*t.....hehe
Old Jan 4, 2003 | 10:54 PM
Lightbulb
PROBLEM FOUND!!!!!!!!!!
Man, i guess when u have to find a problem, u gotta be unbiased and assume that your friends ARE IDIOTS
Turns out the SUBS themselves are bad. Took my JBL 12" out of my blazer, hooked it up to the amp, and BOOM - Bass is back
I'm never buying anything used again! friends or not
Looks like I'm in the market for some new 10"s.
IM thinking of going with Image Dynamics or Eclipse. What do u all think? Those IDs are well worth the money from what i've seen and the experience i've had working on them.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
