Wiper arm removal rant
Old Oct 12, 2008 | 04:02 PM
moparman's Avatar
I've been trying to repair the windshield wiper washers. The fluid leaks out from under the cowling. Bought all new hose and connector. Tried a battery terminal puller, and just bent the handle on it. I then bought an OTC 4676 windshield wiper arm puller. It looks like it will do the trick. Well, it won't fit properly. I modify it by doing some grinding on it. I get it to where it fits properly. I begin turning the ****, and as it begins to pull, the damned **** you turn to exert the pressure on the spindle comes off. Frustrating.
How do you get these #$&@ arms off?
Old Oct 12, 2008 | 05:35 PM
Angelis83LT's Avatar
What car is it for. if the 4th gens are like my 3rd gen. then there is a flat retainer you have to pull out first, then you pull the arm off. It looks like a U, and fits right under where the arm connects. How else do you figure they always stay on lol.
Old Oct 12, 2008 | 06:52 PM
moparman's Avatar
It's a '96 Firebird. There's a nut that screws down on top of the arm.
Old Oct 12, 2008 | 07:12 PM
jeremy stanke's Avatar
i cant get mine off either, i have a 4th gen also
Old Oct 12, 2008 | 07:13 PM
check to make sure that is does not indeed have a clip on the bottom. not really easy to see. Only reason that you shouldn't be able to pop it right off with you hands
Old Oct 12, 2008 | 07:16 PM
mdacton's Avatar
put some pb blaster on it.....
wiggle it, and then use the remover if you need to. there is no clip on it
Old Oct 12, 2008 | 07:31 PM
moparman's Avatar
I let them soak overnight in PB Blaster, then put some Liquid Wrench on them a few minutes before trying to remove them. Can't get the **** back on the puller.
Old Oct 12, 2008 | 07:32 PM
mdacton's Avatar
why not?
Old Oct 12, 2008 | 07:47 PM
moparman's Avatar
The end the **** goes on is splayed. It's larger than the opening in the ****. I don't know for sure, but I'd guess when the **** is put on in the manufacturing process, that it is warm enough to stretch over the end, and when it cools it contracts. There is a slot in the end of the rod the **** goes on, like a notch for a screwdriver. I've thought about using some large pliers and closing it up some, then putting some super glue on it and forcing the **** back on. Not sure the glue will hold.
Old Oct 13, 2008 | 10:41 AM
Sick97SS's Avatar
you know they make a wiper arm puller tool for about 10 bucks. its worth for risk of cracking your windshield.
there's no clip, just the bolt on top, they are just really snug!
Old Oct 13, 2008 | 11:44 AM
moparman's Avatar
If you read my first post, you'll see I bought one of those. It did not fit. When I got it to where it would fit, the **** came off.
Old Oct 13, 2008 | 12:23 PM
Sick97SS's Avatar
ahhh sorry about that,...
my wiper bolt is slightly indented on the top so the round part of the puller fit snug.
Red Hawk 94
Mar 18, 2019 04:03 PM
KYWes
May 22, 2015 08:48 PM
canbaufo
May 5, 2015 03:43 PM
R@mpage
Apr 20, 2015 10:02 AM
stopthatman
Feb 9, 2015 09:00 PM
