Throttle cams and throttle cables.....
Old Oct 8, 2008 | 01:41 PM
Sparkz28ss's Avatar
98-99 LS1s use the small throttle cam on the tb and the 00-02 cars use the larger throttle cam.If one wanted to swap from a small cam TB to a TB with the larger throttle cam then all that needs to be done is to swap to the matching year throttle cable?Is that right?
LS1 throttle body (98-99 F-body) (small cam on throttle shaft end; brown spring) = 17113390
LS1 throttle body (00-02 F-body) (large cam on throttle shaft end; blue spring) = 17113647
LS1 throttle cable (98-99, with traction control - RPO NW9) = 12552267
LS1 throttle cable (00-02, with traction control - RPO NW9) = 12563651
LS1 throttle cable (98-99, without TCS) = 12565559
LS1 throttle cable (00-02, without TCS) = 12565560
Old Oct 8, 2008 | 03:28 PM
Marc 85Z28's Avatar
Or you could swap the throttle body shaft, which is what most people do.
Old Oct 8, 2008 | 05:40 PM
Sparkz28ss's Avatar
one is ported ....
Old Oct 10, 2008 | 08:12 AM
Marc 85Z28's Avatar
Originally Posted by Sparkz28ss
one is ported ....
So? The throttle shaft will still swap.
Old Oct 11, 2008 | 04:22 PM
Sparkz28ss's Avatar
i know that,i dont want to have to rework another shaft
but back the question at hand... swap cables?
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
