Cutting out or removing interior metal - how?
Old Sep 21, 2008 | 06:13 PM
neversummer's Avatar
I've gutted the interior and am trying to remove the panels that are tac-welded on that supported: the rear selt belts, the rear seat lock, the rear cushions, and a few other welded on plates that look removable. My question is what is the easiest way to get these out? I have tried grinding just on the tac weld and that takes a long time. Someone suggested some sort of snippers? A cold chisel and big hammer? I'm afriad that would dent up the necessary framework. Torch them out w/ plasma cutter? - that too may damage the hull.
Any thoughts would help. And any other panels I can remove would be great information. FWIW I've pulled out over 300 free pounds. I'm looking for another 100. Then it will cost me to remove weight.
Old Sep 21, 2008 | 11:42 PM
Cut-off wheel on a grinder? Air hammer with proper bit? Probably some other choices out there, too.
Old Sep 22, 2008 | 10:43 AM
slomarao's Avatar
what does it weigh now?
Old Sep 22, 2008 | 12:00 PM
I have not had it on a scale. I plan on it this month though. I'll post up the weight when I weigh it.
Old Sep 23, 2008 | 08:58 AM
RUDEDOG's Avatar
Get a nibbler. 25 bucks at on Harbor Freight Tools weTake a look at this item I found on the Harbor Freight Tools web site.
I thought you might be interested.
16 GAUGE AIR NIBBLER
http://www.harborfreight.com/cpi/cta...emnumber=46061
bsite.
Old Sep 26, 2008 | 01:26 AM
form94's Avatar
Did u try a spotweld cutter/bit? You use it like a drill bit but its made just for spot welds.
Old Sep 26, 2008 | 01:16 PM
97FormulaWS-6's Avatar
Spot-weld cutter, best tool for doing what you're trying to
Old Sep 30, 2008 | 03:04 PM
tomcowle's Avatar
Zip wheel and some skill.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jun 6, 2015 08:27 AM
squarehead
Nov 21, 2014 08:02 PM
