Newbie here, any advise
Old Dec 30, 2002 | 11:56 PM
v10power's Avatar
I am picking up a 99 z28 from the stealership next week and was wondering if there is anything I should know or any advise you can give me about this car? its a 1999 Silver z28 with t tops and ground effects package. Car has 43000 miles on it and a borla exhaust. Other than that I think it's stock, didn't see anything aftermarket under the hood. I am going to put a cold air intake on it first but what else bolt on really wakes this motor up? THanks for the help guys!
Old Dec 31, 2002 | 12:00 AM
redz_02's Avatar
how much you wanna spend. I would say get an airlid. A good place to go is www.thunderracing.com . An airlid will complement that exhaust. If you got about 400 bucks, i would buy an ls6 intake, that will also wake that car up a little. An airlid takes about 20 minutes to put on. Easiest mod on these cars.
Old Dec 31, 2002 | 08:13 AM
bbentley40's Avatar
Well if the car is a M6 I would suggest !CAGS.. first time it tells you that you have to shift into 4th when you want 2nd should **** you off enough to spend that 30 bucks. I would suggest checking into www.installuniversity.com and look for all the free mods. None of them are going to give you a huge power boost, but for free they are worth doing. Other than that I think a lid should be your first thing. LS1's react very well to better breathing, and if you already have a Borla on the back you can start working on the front and work your way back.
Congrats on the car! Let the addiction begin.. hehe
Old Dec 31, 2002 | 10:17 AM
Black01_Z's Avatar
If your gonna put on an Intake definetly skip the lid and go with the K&N FIPK. They may be a little pricier but these things are beasts. I have no regret purchasing mine. How many bolt on mods are there where you actually feel the difference. You can buy one at a local auto parts store. Then my advice is go with gears.
Old Dec 31, 2002 | 10:45 AM
v10power's Avatar
Guys, Thanks for all the advise and the links, your awesome!! Just heard from the stealership and I may be able to pick up the car tonight, it won't be registered or insured yet but I 'll take the GN out of the trailer and put the Camaro in for now. I have already asked a buddy of mine to make a cold air intake pipe that'll go from the throttle body down inside the fender I believe, I'll send a pic when I see what he actually does to it. Besides that, I am going to do minor things for now, my goal is to get it into the high to mid 12's as it is my wifes car technically! I have my dually as a daily driver and my GN for pissing on the imports at the track!! Thanks alot guys!!!
Old Dec 31, 2002 | 12:00 PM
transam8's Avatar
Sub-frame connectors make a huge difference for these cars. They will help keep everything tight and prevent flexing. I would get a set of those asap if your car doesn't already have them. Good luck, and congrats on the new ride!
-Mike
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
canuck94z28
Aug 19, 2015 05:50 PM
chuyz28
Jan 27, 2015 08:53 AM
Z28countrymama
Jan 22, 2015 02:50 AM
