cooling fan relay on '92 RS?
Old Dec 30, 2002 | 12:11 PM
ggsz28's Avatar
As I understand there are 2 relays on the firewall...one for the fuel pump and one for the cooling fan. Which one is which? The fan doesn't come on unless the A/C is on and so I'm replacing the relay to try and fix the problem.
Thanks,
Geoff
-the car is a '92 Camaro RS w/ the V8
Old Dec 30, 2002 | 11:47 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
I'd say its a problem with the temp switch on the passenger side head before I would mess with the relay. You say the fan is coming on with the A/C, so the relay is sending the power. The stock fan switch is set for something like 230º, way too high.
Old Dec 31, 2002 | 01:29 AM
aklim's Avatar
Simple enough. Disconnect the wire and ground it. If the fan does not come on, next thing to check is the relay.
Old Dec 31, 2002 | 09:50 AM
IrocAngel77's Avatar
my firebird had a similar problem..but the relay switch completely died..then the fan motor went all at once causing a small elecrical fire burnt all my wires up lol
Apr 27, 2015 06:08 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
grabbem88
Apr 16, 2015 06:57 PM
