strange new sounds from the trany... help!!
Old Dec 30, 2002 | 02:38 AM
W3dgy's Avatar
in my last post i was asking about the shift stops on a b&m shifter. well i got the shifter installed and didnt use the stops. but now i get all kinds of sounds from what seems like the trany. its a high pitch sound along with a grinding sound. it even has the sounds when its in nutrle "it gets louder when i rev it ". the install went fine, and the shifter feels good. what the heck could this be i think im guna reinstall the stock shifter and see if its still got the sound.
Old Dec 30, 2002 | 03:11 AM
stik6shift98's Avatar
thats a good thing to start with..........
but im pretty sure it has nothing to do with shifter.... i guess well have to wait and see
Old Dec 30, 2002 | 08:33 PM
W3dgy's Avatar
Question
Dont everyone jump up at once.
some one has to have had the same problem..
any ideas?
Old Dec 31, 2002 | 10:55 AM
psychocabbage's Avatar
Perhaps you removed some sound dampening or insulation when you did the install... Just a thought..
Old Jan 1, 2003 | 01:12 AM
venomcure98's Avatar
I have the same exact noise on my after my B&M install, it is just because u ripped off the "factory" insulation and no amount of ATV sealant or anything u do will get it go back to being as quite as the factory seal. Dont worry about anything it is perfectly normal! Just turn the radio up
Old Jan 1, 2003 | 01:14 AM
by the way, DONT USE THE SHIFT STOPS!! they can cause major damage to ur tranny if not installed perfect!
Old Jan 1, 2003 | 09:55 PM
W3dgy's Avatar
ok so i took the b&m out and reinstalled the stock one. took it around the block and no sound. so then i reinstall the b&m "test fit.. no RTV no console just the rubber boot over the top." and there was no sound. so i took the shifter out hit it with the RTV and reinstalled every thing. took it aroud the block and the frekin sound was back!!! guna take it apart and try one more time tonight. and im not going to use the shift stops. thanx for the input.
Old Jan 2, 2003 | 01:30 AM
W3dgy's Avatar
ok i found the problem. you are going to think im crazy, but its the shift ****. i took it all apart and checked every thing. took it around the block and no noise.( no console, just the boot over the top) so i install the console and everything. and the noise came back. so as im driving home i start to unscrew the shift **** cuz im got to take every thing back out, as soon as i got the **** off no noise! the one that i had on was the b&m short leather one. i tryed the stock one and it still had the same noise. im lost..
shift ****= noise
no shift ****= no noise
btw i smoked an old guy in a 2002 mustang gt today...
he started it
Nayr
Mar 3, 2023 08:34 PM
rvonsternberg
Sep 14, 2015 11:58 AM
95craz28
11
Sep 12, 2015 07:47 AM
jackpawt883
Sep 10, 2015 08:53 PM
tdigger9899
Sep 7, 2015 10:56 AM
