TunerPro RT and DA3 Definition
Old Sep 3, 2008 | 10:07 AM
sleeperLT1Z28's Avatar
I have discovered that I have an incomplete .xdf definition file that I am using with TunerPro RT. The file is called DA3, which is the correct one for a 93 LT1, but it does not have nearly all the tables and constants that it should. Also, I contacted TunerCat to see if the definition file they have for sale would work with TunerPro RT, but they say it is not compatible. Does any one here have a DA3 definition file for TunerPro RT that has tables like LOW OCTANE ESC MULTIPLIER vs RPM and LOW OCTANE ESC MULTIPLIER vs MAP?
Old Sep 4, 2008 | 10:18 AM
bobdec's Avatar
sleeper, I looked at the TunerPro DA3 download bit definitions file and those tables are not in it. Apparently no interest in the older stuff. Have you tried the TunerPro GM Definitions forum, maybe you could get something over there that has something. Otherwise it looks like you will need a hack to add the tables. " http://forum.tunerpro.net/viewforum.php?f=7 " . Another path .. if your sure TunerCat has the tables in their $DA3 you can download the 30 free trial 'Tuner' program and pay the $19.95 for their definition file. If you like TunerCat then it's $69.00 after the 30 days to register it. Assume you already have the EPROM programmer.
CARiD
Sep 30, 2015 05:44 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
