Headers
Old Dec 29, 2002 | 09:25 PM
Mellowdork's Avatar
Headers
Hey guys. I just got my bbk shorties in my 96z. Took it for a test drive today. Theres a more vibration than before. Is that normal? If not then i must have put something back wrong. Another thing. I was thinking about geting some kind of heat shield stuff for the wires down there. How close can a wire be to the header before melt down? couple inches for enough away? Well not just plug wires, i just noticed the o2 wires and such are pretty close. thanks
freddy
Old Dec 29, 2002 | 09:39 PM
chesee48's Avatar
i think theres a lot of people who noticed that vibration as well, so im sure u'll get replys...i personally didnt
did u use stage 8 lockin bolts?
the wires would be ok as long as there not touching the headers so a few (like 3-4inches) should be ok...did u use ties to hold them away?
Old Dec 29, 2002 | 10:00 PM
Mellowdork's Avatar
Yes on the bolts. The header holes didnt match exacly so we had to do some work to get them on. I knew this going in though so its okay. Why do you ask about the bolts? Bolts can give me vibration problems?
Yeah I used zip ties on some of the wires. I just couldnt get them to far away cause theres isnt much room to play with..
thanks for the reply.
freddy
Old Dec 29, 2002 | 10:05 PM
chesee48's Avatar
i just thought maybe there were a little loose (the headers)
but those bolts are preety damn good...
Old Dec 29, 2002 | 10:16 PM
97WRAITH's Avatar
I have the same Headers and did not experience any vibrations.As for the wires as long as they don't touch you should be o.k. you might want to upgrade your wires if you haven't done so.Also you should keep an eye on the bolts the will keep backing off. I would get 1 inch long bolts 3/4 inch are too short.
Old Dec 29, 2002 | 10:44 PM
Snoochies's Avatar
My BBK headers have never made any noises
Old Dec 29, 2002 | 11:14 PM
Z95m6's Avatar
vibration probably = burnt plug wire.
Old Dec 30, 2002 | 12:23 AM
Mellowdork's Avatar
Well its not missing or anything. just sorta feels like exhaust is up against the firewall. but its not. its not that much but i just wanted to make sher this is normal stuff.
Old Dec 30, 2002 | 12:43 AM
Smokn '94 Z's Avatar
Lightbulb
How are your motor mounts?
Old Dec 30, 2002 | 01:20 AM
Mellowdork's Avatar
hmm. havnt checked those. Ill take a gander at them tomarrow. Im gonna check some other stuff as well. Im gonna check my Y pipe and stuff as well. There has to be something. Now i know this isnt normal. thanks fellas.
freddy
Old Feb 6, 2003 | 07:32 PM
frankjr8's Avatar
Ever find the rattle?
Old Feb 6, 2003 | 09:39 PM
Mellowdork's Avatar
Yes. It was a number of things actually. My Heat sheild on the pas. side was rattleing a bit. So i just took the thing out. The other problem was the Y pipe was vibrating on the "g force brace" or whatever they call that thing. So i put some washers in there as spacers.
Doing this it did stop some of the vibration and totaly stop the rattling. But I still have a little more vibration than before the install. Im use to it now.
As for my plug wires I replaced them in the header install but i noticed one had gotten burnt. So I have the taylor 8mm over the vavle cover kit comeing from thunder racing.
Old Feb 7, 2003 | 01:32 AM
Mellowdork's Avatar
What i took off was the 5inch piece that rolled up onto the firewall.Not the WHOLE thing. That would just be dumb. And no im not putting back. Its been off for a month and 2, 800 mile road trips. Hasnt burned a hole in my car yet.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
