Power Antenna Camaro and Firebird Interchangable?
Old Aug 24, 2008 | 10:30 AM
A35TH-SS's Avatar
I am looking to install a power antenna on my 02 Camaro but wanted to know if the power antenna from the Firebird (10482860) is the same as the camaro (10482859) power antenna, it's for a convertible.
Old Aug 24, 2008 | 09:46 PM
bmnicolosi's Avatar
Camaro's dont have power antennas
Old Aug 26, 2008 | 06:28 PM
A35TH-SS's Avatar
I see that this GM antenna fits a Camaro.
Old Aug 26, 2008 | 10:56 PM
bmnicolosi's Avatar
i put a power one on my first 99 z and my current one, they just didnt come with them. The gm one {used in the t/a} works fine, or an aftermarket one will work also, just need to run a turn on, as the camaro's dont have one.
Old Sep 11, 2008 | 01:40 AM
burnout96's Avatar
its cake... worse part is removing old antenna and finding wires to get power and turn on from
Old Jan 11, 2009 | 10:17 AM
A35TH-SS's Avatar
Just finished the power antenna install. I followed a couple How-To's found here and on the web. The things I did a little different were sodering the connector to the wire before inserting it into the radio connector. I also covered the wire from the radio to the antenna with 1/8" loom. This will protect the wire. I grounded the antenna to a nut holding the bumper on. Any metal to metal ground will work. I also cut one of the Orange power wires to the factory amp and used a butt connector with heat shrink tubing. One end went to the connector and the other I connected both the antenna and the other end of the cut power lead.
Old Feb 15, 2009 | 10:01 PM
96' Formula WS6's Avatar
Also if you have an aftermarket stereo you can just hook it up to the remote wire
F'n1996Z28SS
Aug 23, 2023 11:19 PM
siguy
Nov 27, 2014 10:07 AM
97_396_WS6
Aug 4, 2002 10:23 PM
Red97LT1
Aug 3, 2002 07:29 PM
tybz28
Aug 1, 2002 03:34 AM
