How can I tell the difference between the n2o and fuel solenoids?
Hello everybody,
I’m piecing together a n2o kit. I recently ran across a set of solenoids; however, the guy selling them had the covers chromed, and didn’t bother to mark which one was the n20, or which one was the fuel solenoid. Both seem to be identical in every way. Is there a way I can test them to find out which one is which?
Thanks,
Thanks,
Thanks for the info. They are NOS brand solenoids. I think "PowerShot." They only have in and out. They look just like the ones on NOS's web site. This is where I got the idea to check the amps, just not to sure what the best way to do this would be.
You need to open the solenoid and measure the orifice. The larger one will be the fuel. For your info, you can use a nitrous solenoid for fuel, but you cant use the fuel solenoid for nitrous. The fuel solenoid draws less amps, becuase it can get away with using a smaller coil. Its easier to open against lower fuel pressures (6-60psi) then the nitrous pressures (700-1100psi). If you have any more questions, email me and I can help you figure it all out.
You can't use a nitrous solenoid for fuel, at least not for long. The plunger in a nitrous solenoid is made of a material called RTM which will not tolerate exposoure to gasoline. That is why on plate systems you don't want to mount the solenoid lower than the plate. The fuel solenoid use a seal made of viton which is desinged to handle the fuel.
If you are using any of the NEW solenoids, which have been on the market for at least 7 years, then the nitrous solenoid can be used for fuel. The material on the plunger, if its a good solenoid, is made from teflon, which handles fuel just fine. Have done it for years.
Teflon is a difrent subject. Yes it can be used for fuel but it also has a problem sealing. Not all new solenoids come with teflon plungers. Teflon doesn't have the memory of the RTM so if any debris get in the soenoid between the plunger and the seat the solenoid will not seal and can leak. Teflon is great on race cars and progressive kits but not always the greatest idea on a street car. But telling some one they can run a nitrous solenoid as a fuel solenoid with out specifying the fact that it has to be a teflon plunger could lead somne one to ruin a plunger not to mention the headache when the can't figure out what is wrong with there nitrous kit.
Jul 4, 2005 05:00 PM
