CD Player randomly stops working? Help
Old Jul 26, 2008 | 10:22 PM
6SpdLT1Z's Avatar
Question CD Player randomly stops working? Help
I have a '97 SS with the factory Delco CD Player. Randomly while driving my radio will stop playing, no display, nothing, as if it has been unplugged. During this time I have also noticed that my windows will not respond to the switches. A couple minutes later my radio will kick back on and everything will be fine. It's starting to annoy the hell out of me and I have no clue where to look. All the fuses appear fine.
Old Jul 28, 2008 | 04:40 AM
6SpdLT1Z's Avatar
Anyone? I've got a couple days off next week and I want to figure this **** out.
Old Jul 30, 2008 | 07:30 AM
Chevyssoccer's Avatar
This is just a possibility. The RAP circuit keeps the radio, windows... powered after the key is turned off until the door is opened. I would guess the problem might be there.
Old Jul 31, 2008 | 03:48 PM
6SpdLT1Z's Avatar
I turned the volume down a bit and it's not doing it. I think I might've been overheating it.
Old Jul 31, 2008 | 04:20 PM
bluz28's Avatar
Lightbulb
Check for corrosion on the fuses in the fuse block in the car.
Old Aug 17, 2008 | 10:44 AM
POS Camaro's Avatar
Sounds like there is a self resetting circuit breaker that is tripping. Check that for corrosion and possibly replace it. It may be getting old and has a high resistance that is tricking the thermal overload into tripping early.
Old Sep 1, 2008 | 04:51 PM
waittill2009's Avatar
Yeah, go on eBay type Camaro radio, and some results will come up. I found 14 matches. Or Craigslist.
Old Sep 1, 2008 | 05:09 PM
94Phoenix's Avatar
i used to have a 92 gmc sierra that did this same thing, it only did it when i had it turned up high, it would completely shut off, and then come back on. had that truck for 2 years and never did figure it out, lol
Old Jan 14, 2013 | 03:42 PM
6SpdLT1Z's Avatar
Re: CD Player randomly stops working? Help
I was looking for an old thread I started and noticed this thread in my search. Figured I'd update it with a resolution for anyone searching in the future.
The problem ended up being bad solder joints on the BCM. I pulled the BCM, used de-soldering braid to remove the solder and resoldered the joints.
How To Fix Intermittent Windows, Radio and Locks
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Rod Bender
Jan 3, 2015 03:15 PM
Chicago94Z28
Aug 28, 2002 08:31 PM
