locating low side on A/C?
Old Jun 27, 2008 | 01:44 PM
eliX0r's Avatar
I know alot about cars but nothing about air conditioning. how do i locate the lowside to recharge the a/c on a 95 camaro z28 or can someone tell me where it is located.
Old Jun 27, 2008 | 09:12 PM
eliX0r's Avatar
any1 know where it is or how i find it since it doesnt say in the manual. plz help me and my 2 yr old are roasting in this hot weather.
Old Jun 27, 2008 | 09:16 PM
crazypurgatory's Avatar
On the passenger side there should be two ac lines.
I'm not sure which one is the low side but if it's got 134A in it the recharge fitting will only fit the low side.
The fitting for the high side is a different size.
You "must charge from the low side" you can burst the freon can if you charge it from the high side.
Old Jun 28, 2008 | 09:11 AM
Nuke's Avatar
There's two schrader valves for the AC. They are both on the passenger side of the car with plastic screw-on caps on them. One is toward the front of the car by the passenger side headlight - this is the high side and your recharge fitting will not fit on this. The other is about 3/4 the way back toward the firewall - this is the low side and your recharge fitting should fit on this one. The low side valve is smaller than the high side.
Old Jun 28, 2008 | 09:52 AM
JP95ZM6's Avatar
The larger diameter lines are low side, smaller ones high side. Easy crib for any A/C system.
Old Jun 28, 2008 | 10:32 AM
eliX0r's Avatar
thanks for the help, i appreciate it. recharge took and the air is nice and crisp. no more sweating the boys in a blackcar with black leather.
HectorM52
Jun 23, 2016 08:42 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
alphaauto
Feb 5, 2015 05:25 PM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
