Fra
Old Dec 24, 2002 | 12:19 PM
Flat_Tire_'s Avatar
Fra
You guys who have FRA, how often are you cleaning your air filters? I'm thinking I'll do it anyways and if dirt builds up too much and too often ill replace the cut parts from GM. Are you guys happy with it? Were there noticable differences after performing it?
Old Dec 24, 2002 | 01:44 PM
mark896's Avatar
If you're talking about the mod where you cut the plastic above the radiator (and condenser), do it. My air filter hasn't been changed since I did it and I have a WS-6. I did notice a difference too. Definitely worth it.
Old Dec 24, 2002 | 01:52 PM
2001NBMZ28's Avatar
I did the FRA last year, only cleaned my filter once. Liked it so much I installed FTRA too.
Old Dec 24, 2002 | 03:56 PM
katman's Avatar
I clean my AF every couple months just for GP's. With a K&N, why not? The FRA mod is a definate power-adder.
Old Dec 24, 2002 | 04:50 PM
96SFLZ's Avatar
After I did the FRA, the filter definitely gets dirtier faster but IMO, it's worth it. Well, I couldn't exactly feel a difference but I'm guessing it probably did help a little, I just can't feel it...I couldn't feel a difference on my '96 after I did Hooker LTs and I gained 4 mph at the track, just to give you an idea of what I can/can't feel
Old Dec 24, 2002 | 05:02 PM
stik6shift98's Avatar
whats fra???????
Old Dec 24, 2002 | 05:11 PM
katman's Avatar
FRA=Free Ram Air
Old Dec 24, 2002 | 05:18 PM
oh........is that when u cut bottom right bellow lid out
Old Dec 24, 2002 | 06:48 PM
Flat_Tire_'s Avatar
Ya you cut the bottom of the air box assembly and a hole in the air baffle...
http://www.f-body.org/rob/98z/ramair/index.htm
or installuniversity.com under install documents, free ram air.
Old Dec 24, 2002 | 06:55 PM
ya i did that...i think......
well i have whisper ram air so u have to do it right.....
and i have a lid so baffles thing is gone
Old Dec 24, 2002 | 07:00 PM
Flat_Tire_'s Avatar
No, those things behind the lid before are air silencers. FRA includes cutting a flap/air baffle beneath the airbox assembly and in front of the radiator. Look at the pics in the sites I posted.
Old Dec 24, 2002 | 07:06 PM
im sayin i got a new lid and it required removing baffles
like a whisper lid or slp lid
Old Dec 24, 2002 | 07:09 PM
Flat_Tire_'s Avatar
Ya... but are you referring to the baffles/silencers behind the lid or are you reffering the pieces below the filter, which includes part of the air box assembly, and further down there's another baffle that you cut a hole in for FRA. Maybe I'm just confused.
Installing a lid doesn't require FRA. FRA is further work, involving cutting into items beneath the air filter.
Old Dec 24, 2002 | 08:08 PM
ratio411's Avatar
The FRA mod is a 'must do'...
Your filter will dirty quicker, the rear half anyway. When the rear half is dirty, rotate the filter so the clean part is in the rear. Your filters will last twice as long.
Dave
Old Dec 24, 2002 | 08:18 PM
im sayin u have to do that cutting when u get whisper ram air or fast toys ram air......
