Vortec TPI to carb. set up ideas
Old Jun 25, 2008 | 03:16 PM
1987IROC350's Avatar
As many of you know I purchased a Scoggin Dickey Vortec TPI engine a couple years ago. The car is running very rich and I won't drive it. All my attempts to get the OBD I computer properly dyno/tuned have fallen through. This not being a car shop town I've just decided to go with a carb. set up. I just want to drive the car I've spent 10K on with all the new parts.
I was looking at the almost complete combo from Summit with dual-quad intake for the Vortec. It's $1,085. Is this good for a car that will be used mostly as a daily driver. MPG is not a concern? http://store.summitracing.com/partde...6&autoview=sku
If it is not a good streetable combo what intake and carb. do you suggest.? Mostly a daily driver but will race a couple times a month locally. Mods are in sig.
I noticed some intakes are rated at idle to 5500rpm or so and some are 1500rpm to 6500rpm. My redline is only about 5800 in my crate motor. So I guess the idle to 5500 would be best.
Any suggestions are welcome. I wanna cruise!
EDIT: are my fans run by the computer or a sensor directly hooked up to my radiator? Just wondering what I'll need to do to make my fans come on at 190* to 210* or so
Old Jun 26, 2008 | 03:35 PM
Rice Killer87's Avatar
Uh oh,going carbed now huh??
Well Ive been here and done that.
The list you will need is as follows:
An adjustable fuel presure regulator that will knock FP down from 36 to 5.5-7.
This is what I used on mine:http://store.summitracing.com/partde...5&autoview=sku
You'll need an HEI distributor b/c your factory one is computer controlled...heres some that will work:http://store.summitracing.com/egnsea...4294840140+115
I would not use that dual quad intake unless you want something really "cool" or different b/c making adjustments is going to be a pain b/c of having to do everything twice!
A Performer intake (idle-5500) will work,but I used a Perf. RPM on mine (1500-6500) and it cleared the stock hood but had to use a drop base air cleaner. I would prob. go w/ the RPM again myself.
Any type of 650 cfm carb will work as well,you dont need a 750 regardless what anyone else tells you. If you want more power than fuel economy,get a Holley...more economy than power get an Edelbrock. Again this is up to you which you want.
You will also need a different torque convertor lock-up mechanism b/c after switching to carb it wont lock up and eventually it'll burn up your tranny. Heres one http://store.summitracing.com/partde...5&autoview=sku
As far as the fans go im not sure...its been so long. When I did mine,I left the computer in the car and hid the harness in the passenger fender....did that so I didnt have to re-wire the fuel pump when the key was on.
Just remembered, I put my fans on a manual switch so I could turn them on earlier and kept the motor cooler.
Any other ?'s feel free to PM me.
Old Jun 26, 2008 | 11:53 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
If you can tune a carb, you can tune EFI. You need tools to tune a carb, and you need tools to tune EFI. You just need the right tools and the right knowledge. Carbs are not easier than EFI, they just require different tools.
Old Jun 27, 2008 | 07:43 PM
87tpita's Avatar
a vortec setup shouldnt have any negative effects, especially with a maf setup, unless you put on different injectors or a cam with a close lsa will cause some serious tuning challenges. I ran a 355 vortec with a performer rpm intake and a 650 vac sec holley running 6 psi of fuel and a mild cam. I had msd ignition, and 3.45 gears stock everything else and I ran a 14.3 going sideways all the way thru 2nd gear. with new tires I wouldve been high to mid 13s all day.Personally I wouldnt get rid of the tpi because of tuning issues but to each there own.
kennyirocz
Feb 7, 2015 11:41 PM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
CaRParts102
Dec 6, 2014 08:45 AM
