CAM guru's---112 LSA on a 383 w/blower.
Old Jun 23, 2008 | 05:54 AM
RUNMYTA's Avatar
After speaking with a few fellow F-body buddys, I have a question about my engine. I had a 383 built for boost. I am running a D1SC and shooting for 15lbs of boost. My engine builder uses a well known shop for heads/cam set-up and they went with a 22X/23X on a 112. Most people are saying that this is to tight of a LSA. What do you guys think?
Old Jun 23, 2008 | 08:19 AM
lt1powa's Avatar
i have a 113 on my setup and works just fine.
Old Jun 23, 2008 | 09:51 AM
Rice Killer87's Avatar
Sounds too tight to me as well...me and dad just put together a 8:1 482 stroker BBC for our Checkmate boat to use w/ a Weind 177 blower and the cam we're using is on a 114.
LSA = valve overlap
overlap = blowing boost out the exhaust
If your engine builder trusts who he got the heads/cam from then it may be alright because running alot of boost like that having a little overlap will help keep the cylinders clear of exhaust gases.
If it doesnt have the power it should,you know a good place to start bitching at!
Old Jun 23, 2008 | 02:07 PM
T/A KID's Avatar
Keep the 112LSA it will work great with your setup. Lobe seperation correlates with duration as far as overlap goes. Some overlap is a good thing with a centri blower car. The specs on my cam is a 224/230 on a 112.
Old Jun 23, 2008 | 09:33 PM
engineermike's Avatar
I like T/AKid's cam better, but I'd keep it. Not even worth the effort to swap out and probably wouldn't gain anything anyway.
Old Jun 23, 2008 | 09:47 PM
That Camaro Guy's Avatar
My cam seems to be just fine, but I'm not running anywhere near that amount of boost.
-Pete-
kaoticcamaross
Feb 17, 2015 03:13 PM
Queens94z28
Nov 20, 2014 06:03 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
