Need Trans Am wire color codes
Old Dec 23, 2002 | 03:49 PM
99_Z_155's Avatar
I am wiring in a new HU in a 2002 TA. I need to know what each of the colors of wires going into the car do, such as power wire, the speakerwires, ACC and so on. Im sure someone has a manual from crutchfield or something. Didnt get this HU from crutchfield so i didnt get the scematics sheet. Thanks guys.
Old Dec 23, 2002 | 08:07 PM
NineSevenWS6's Avatar
Just buy the harness.
Old Dec 23, 2002 | 09:21 PM
moparman's Avatar
Yes, much easier if you buy the $10 harness. No hacking of the factory wiring with the adapter harness.
Old Dec 24, 2002 | 09:23 AM
TEDLT1's Avatar
ORG - 12V CONSTANT
YELL - 12V ACCESSORY
PNK - ANTENNA RAISE (12V)
GRAY - INST DIMMER
BWN - PARK LIGHT 12V
BLK - GROUND
DK BLU - STEERING WHEEL CONTROL INPUT
TAN - DRIVER FRONT +
GRAY - DRIVER FRONT -
LIGHT GREEN - PASSENGER FRONT +
DARK GREEN - PASSENGER FRONT -
BROWN - LEFT REAR +
YELL - LEFT REAR -
DARK BLUE - RIGHT REAR +
LIGHT BLUE - RIGHT REAR -
Keep in mind that these speaker wires are taking the speaker signals to the monsoon system amplifier and the color code is different on the output side of the amp to the 10 speakers.
Old Dec 24, 2002 | 01:26 PM
99_Z_155's Avatar
I wired it up like it says and this is what is happening. The stereo turns on, and i hear the monsoon amp in the back click on. Then sound comes out of the right front speakers. Then if i turn up the HU a ways the amp clicks off, or it just clicks off like after 10 seconds. I dont know what the problem is guys. Im doing this for a friend, and im trying my hardest. The HU is the new Pioneer Premier, if that helps.
Is this supposed to work? I think the amp in the back is overloading itself because the signal it is getting is already amped. The HU is a 50 by 4 i believe. Damn this is complicated.
Do you know what is wrong TEDLT1?
Thanks guys.
Dec 5, 2014 11:42 AM
Dec 1, 2014 08:08 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
Dusty98ta
Aug 14, 2002 04:25 PM
