PCV System Check Valve
Old Jun 14, 2008 | 07:45 AM
joe-96z1le's Avatar
I need a check valve for my PCV system so I don't blow boost back into the crankcase. Where can I pick one up?
Local auto parts store or is there a place I can order online?
Old Jun 14, 2008 | 10:25 AM
FireChicken1995's Avatar
is you plumb it correctly you will NEVER get boost into the system. you have to go like this: valve cover > pcv valve > vacuum hose > inlet side of blower/turbo.
if you place the vacuum hose on the pressure side you are defeating the purpose of the evac system. you want to be sucking air out of the crank case while in boost to lower the crank case pressure so you dont blow a seal out. so if you place that vacuum hose on the pressure side you will only be sucking from the crank case while out of boost... no bueno. in fact if you plumb it right you dont need a pcv valve at all but i would suggest a oil seperator to keep oil out of the intake system.
Old Jun 26, 2008 | 11:15 AM
4SFEDZ's Avatar
but isnt there a check valve that people run in conjunction with the pcv?
Old Jun 26, 2008 | 03:06 PM
Tricked-Out-Toy's Avatar
No, and if they do there isnt a reason for it if they have it routed right.
Old Jun 26, 2008 | 07:59 PM
lt1powa's Avatar
there is one however used on the a exhaust crankcase ventilation type system a one way check valve.
Old Jun 27, 2008 | 10:59 AM
4SFEDZ's Avatar
well i know the pcv valve will not seal completly and when in boost it will leak. i thought i heard of someone running a check valve in conjunction.
Old Jun 27, 2008 | 11:11 AM
your still thinking about it all wrong. you do not want to "seal" off the crank case at any time. under boost is when you want to vent the crank the most since pressure in the crankcase will blow out engine seals.
Old Jun 29, 2008 | 09:46 AM
4SFEDZ's Avatar
i never said anything bout sealing the motor, but just limiting the amount of presure leaking past the pcv. i will be running some type of vac. prob the exhaust evac system.
Old Jun 29, 2008 | 11:51 AM
OBE1 95Z28's Avatar
The Buick GN crowd has been using these for years; I place the supplemental valve in-line with my stock PCV. http://www.psmbuick.com/products_spcvv.asp
Old Jun 29, 2008 | 12:17 PM
Ok they odiously have the PCV mounted somewhere after the turbo. if you mount BEFORE the turbo there is no way you can pressurize the crankcase. please go re read what others have already said about where to mount the PCV. Follow whats been said and you will never have a problem.... A check valve is pointless for this application....
Old Jun 29, 2008 | 07:25 PM
4SFEDZ's Avatar
maybe you should go reread. a stock pcv valve WILL leak and can pressurize the crankcase
Old Jun 29, 2008 | 07:26 PM
4SFEDZ's Avatar
sweet this is what ive been lookin for, is this the same one you are runnin?
Old Jun 29, 2008 | 08:48 PM
Dude read that some more!!!! WITH THE VACUUM LINE INSTALLED BEFORE THE TURBO THERE IS NO POSSIBLE WAY IT CAN PRESSURIZE THE CRANKCASE EVEN WITHOUT A PCV VALVE... Please tell me how its possible that the open to atmosphere intake piping before the turbo miraculously pressurizes the crankcase???? ITS UNDER VACUUM 100% of the time!!!
That check valve isn't used for this application.....
Old Jun 29, 2008 | 10:28 PM
4SFEDZ's Avatar
hey whats your setup? are you fi? and maybe you should read some more bout using vacuum from your turbo inlet to pull vacuum from your crankcase. u ever get on theturboforums? ls1tech? alls i am saying is your stock pcv valve leaks, you can test that yourself (which i have done). some putting a check valve inline with your pcv will eliminate that, thus helping my presure problem. then im goin to run the exhaust evac, not the turbo inlet! the only prob people have had with the exhaust evac is it pullin oil out but you can fix that by using baffles in your vc or runnin a catch can. every setup is diff some people can get away with just breathers on the vc, i can not.
Old Jun 30, 2008 | 12:11 AM
Jay85IROC's Avatar
By what you're describing, the turbo should be sucking any pressure out of the crankcase. Am I understanding you correctly?
Not trying to jump in the fight here, just trying to learn
