FTRA and Direct Flo lid
Old Dec 22, 2002 | 11:28 AM
LBJ's Avatar
LBJ
Thumbs down FTRA and Direct Flo lid
This combo has not proven itself to me yet! I have been to the track 2 time and have been let down 2 times. I know that the Direct Flo is worth every penny but by adding the FTRA I have LOST 1 tenth and gained Omph in the 1/4!!! WTF And those losses where with Nittos running better 60' times Times went something like this....
12.78@ 110.x 60' 1.98
12.80@ 109.x 60' 1.99
12.82@ 110.x 60' 1.98
The Nittos are very consistant, the only complaint is that Iam bogging! Gotta practice on these so I can pull some 1.8x's!
Bottom line the FTRA and Direct Flo are NOT a good combo.
Old Dec 22, 2002 | 02:17 PM
UnbelievabLS1's Avatar
Don't give up yet! The bogging is what's killing your mph and ET. If you bog an LS1 off the line, it takes longer than you think for it recover, hence the lower mph and slower ET. What rpm are you launching at? What do you have air pressure set at in the Nitto's? What you need to do is, launch at a high enough rpm where you slightly spin them, but they're still getting traction, understand? When you're bogging, your car is falling completely out of its powerband, where as when you're slightly spinning, it's staying in the powerband and not losing any rpm's. I usually launched @45-5000 rpm's with the mods in the sig., and although the 60' don't look that great, you can't argue with the results. Just go out and give it another shot, because like anything, it's just gonna take some practice and getting used to.
Old Dec 22, 2002 | 02:19 PM
Freak's Avatar
Re: FTRA and Direct Flo lid
Most of us with that combo would disagree.
Old Dec 22, 2002 | 02:52 PM
LBJ's Avatar
LBJ
Iam launching around 3000rpm and running 18psi in the nittos. Iam kinda ify about launching @ 3500 and higher since Iam still running the stock clucth. The tracks here are closed for a few weeks.
I will give this combo a few more trips to the track I just got spoiled after each previous trip to the track with new best!
Maybe I should run 25psi in the Nittos so I can get a little spin of the line. Iam going to order the Harlen Shift Light today, that should also help keep my e.t./mph more consistant.
Old Dec 22, 2002 | 10:08 PM
Honestly, 3000 rpm's is way too low to launch these cars. Whe I was on my stock clutch, I was launching @5500, but slipping it just a lil bit. By doing that, I was allowing the tires to grab a lil, but still spin a little, and it worked awesome, but you just got to get the feel for your clutch. Whatever you do, DO NOT ride it out, just slip it a tad bit, right until you feel the nose come up, and the weight transfer to the back, and then just dump it and go. You'd be amazed.
Old Dec 23, 2002 | 02:08 AM
stik6shift98's Avatar
not a big fan of that combo........
Old Dec 23, 2002 | 04:31 PM
warbird51's Avatar
I pulled my Direct Flo lid and FTRA. Installed a Stealth airbox assembly. Gained 16 hp and 21 fpds of torque. Definately can feel the gains at all rpm's.
Old Dec 23, 2002 | 06:48 PM
BlackRocketZ's Avatar
Stupid question. Whats a FTRA.
Old Dec 23, 2002 | 06:51 PM
Flat_Tire_'s Avatar
Fast Toys Ram Air... Anyone recommend a Free Ram Air Mod in combination with a Whisper Lid? or can you show proven gains?
Old Dec 23, 2002 | 07:01 PM
Thanks for the info. Without laughing.
Old Dec 23, 2002 | 07:03 PM
Flat_Tire_'s Avatar
No problem... I too wonder about some abbreviations
Old Dec 24, 2002 | 08:32 AM
LBJ's Avatar
LBJ
FRA and Direct Flo Lid work very nice together, or anyother lid i guess. FRA allows access to a bigger volume of air and when you are at speed (65mph +) Iam sure it gives some type of ramming affect.
Henson071
Sep 18, 2015 04:01 PM
cmsmith
Sep 14, 2015 09:25 PM
Bails098
Aug 17, 2015 05:15 PM
surreybrad
Aug 10, 2015 09:34 AM
RX Speed Works
Jul 24, 2015 02:25 PM
