Need help with codes (1416 & 0430)
Old May 27, 2008 | 08:00 PM
Kris93/95Z28's Avatar
I got 1416 the other day. I replaced both the AIR check valves with GM PN 12565503 today. I disconnected both of the battery terminals for about 5 minutes, then fired up the car. I am still getting the SES light. I went to get it scanned again and now its throwing the 0430 (twice) and 1416.
From what I can tell, the 0430 will be taken care of with a new catalytic convertor (which the car should still be covered under with GM's emission warranty), but what needs to be done to clear the 1416 error? I searched and was pretty sure that the check valves would do the trick.
Thanks in advance for all help!
Old May 27, 2008 | 08:45 PM
2001NBMZ28's Avatar
I'd try resetting the PCM this way and see what happens:
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses
Wait 5-10 min
Turn ignition off
Replace fuses
Was the passenger side valve clogged real bad w/deposits?
Old May 27, 2008 | 10:14 PM
Wait 5-10 min
Turn ignition off
Replace fuses
Where can these fuses be found? I think you're talking about the fuses on the side of the dash? Correct?
Old May 27, 2008 | 11:35 PM
2001NBMZ28's Avatar
They're under the hood. After resetting the idle will be a little grumpy until it relearns.
Old May 28, 2008 | 06:46 PM
Thanks for the information. The dealer is going to replace the cats under warranty. Hopefully that will clear up the issue for another few years. This is the second set of cats that car has went through in 60,000 miles (First time they were replaced at 20,000 miles)....
I am not sure why this is happening. I ony run premium fuel, and the only moifications are a lid and a cutout.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
