Wastegate vacuum signal tubing-What are you using?
Old May 19, 2008 | 05:29 AM
DirtyDaveW's Avatar
I'm about to plumb the lines but I got to thinking, "Doesn't this wastegate get damned hot for typical vacuum line tubing of the sort you would use up on top of the intake manifold?". Are you guys using 'normal' vaccum line that you can get at any automotive store or are you using a silicone version of some type?
Old May 19, 2008 | 10:29 AM
Sparkz28ss's Avatar
use silicone tube... i holds up to the heat a lot better the the rubber stuff, the rubber line can crack and fail...and thats no good
http://store.summitracing.com/partde...part=spe-28906
magman
Apr 15, 2016 03:08 AM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Aaront810
Sep 11, 2015 11:24 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
