Need some th350 help.....again
Old May 9, 2008 | 11:04 PM
mdacton's Avatar
Frank hope you know what is going on here, I have no ideas
Made a pass....seemed like the trans was slipping. came back checked everything out, went to go try again....
Put it in reverse and some clunk/grinding......didn't know what it was. Tried in forward gears and it was fine for about 150 ft. The it just free wheeled. I had nothing, no R, 1,2 or 3...nothing. Cut it of looked under it etc checked linkage......Thought maybe I was crazy so started and tried again...worked fine with no problem. So I pull it on the trailer....about halfway up a hard jerk like something broke......but it still pulled.
Any ideas at all? I plan to get it out and apart in the morning.
Damn converter isn't going to work either, way too tight
Old May 10, 2008 | 09:18 AM
12SCNDZ's Avatar
Usually a grinding points to a grenaded planetary.
I've got a really nice manual valvebody TH350 sitting in the shop that I'll let go for $750. It's the one out of our 10.8 second '70 Camaro.
Frank
CPT
Old May 10, 2008 | 10:55 AM
mdacton's Avatar
Is it a forward or reverse pattern? I want a forward, that how my shifter is set up for.
I will let you know on that, I need a converter too. But I'm going to pull it out now and get it apart, see whats up and try to make it to the EFA shootout. If you go to it frank I might try and get the 350 from you while I am there. Either way I should be going, just with another car....
Old May 10, 2008 | 01:03 PM
12SCNDZ's Avatar
It's a standard pattern with a Turbo Action valve body.
Frank
CPT
Old May 10, 2008 | 03:37 PM
mdacton's Avatar
Frank
CPT
Cool, thats the same one I have.
Now I got this thing out and torn down......does not smell too burned up.
The low/reverse ( i guess clutches) all the way in the rear....they are smoked.....all black looking.
The front planet inside the sun shell looks like it was riding on the sunshell. But it has the thrust bearing in it. But, you know the sun gear has the 2 snap rings like wire type....well the front one was off just laying in there all stretched out. I'm thinking it was pushing it back and the shell was slipping around where the snap ring goes....
Does this sound reasonable? And why the hell would my low/rev. be burned up? When I first installed this trans I used the cheetah vb but forgot something (the mod. valve) so I'm thinking it smoked em then even thogh I didn't even move it 200 ft. but it was really jerking feeling.
You going to make it to the shootout?
Old Jun 2, 2008 | 10:32 PM
mdacton's Avatar
Frank
CPT
Yo When can I pick it up. I need it yesterday
Old Jun 3, 2008 | 12:54 AM
12SCNDZ's Avatar
This thing looked amazingly well for all it's been through. The forward frictions were flaking a little. I've got the parts ordered to put it back together. should be done by Thursday.
Frank
CPT
Old Jun 3, 2008 | 06:16 AM
mdacton's Avatar
Frank
CPT
Well I will drive up there to pick it up.
Old Jun 5, 2008 | 10:17 AM
mdacton's Avatar
Let me know whats up...I'm ready to leave.
james4154
Jun 15, 2015 12:16 PM
72Demon
Classic Engine Tech
Feb 19, 2003 06:43 PM
IROC86
3rd Gen / L98 Engine Tech
Jan 5, 2003 01:09 AM
94-3.4
Nov 24, 2002 08:26 PM
Nostang 96z
Sep 14, 2002 08:22 PM
